What voltage can GH4 handle? - Page 2 at DVinfo.net
Old October 17th, 2014, 09:24 AM   #16
Re: What voltage can GH4 handle?
Thanks Alex
Have you better proposals how to use our standard Lion batterys with the GH4 to spare some loss?.
I have tried the 12V outlet in my Dynacore D_C adapter and it works fine too - to split some of the heat.
A LM7809 is also mounted on one of the outlets so I can supply the camera directly from that.
Bo Skelmose is offline   Reply With Quote
Old October 17th, 2014, 11:55 AM   #17
Contributor
PM sent, trying to keep business separate from good conversations :-)
Alex Dolgin
Dolgin Engineering
Camera DC Power accessories, Fast 4 position Battery Charger
http://www.dolgin.net
Alex Dolgin is offline   Reply With Quote
Old October 17th, 2014, 01:21 PM   #18
I have decided to play it safe and go for a Switronix cable, as suggested by Phil Goetz.
http://www.switronix.com/products?pa...category_id=56
Cees van Kempen
www.iwp-wildlife.com
Cees van Kempen is offline   Reply With Quote
Old October 17th, 2014, 09:23 PM   #19
Hi
That cable is great. Unless there are a switchmode supply inside the case it will give the same result as with the LM7809 regulator. :)
Bo
Old October 17th, 2014, 10:42 PM   #20
Hi guys,
Does anyone have any feedback on this-
External Rechargeable Battery for Panasonic GH3 GH4 Video 8500mAh DMW DCC12 | eBay
Or, can anyone point me in the right direction to something similar?
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old October 18th, 2014, 01:47 AM   #21
Originally Posted by Bo Skelmose View Post
Hi
Bo
I think that they will have another solution with no chance of overheating. At least I hope so for more than €70.
I have ordered one to test, which I can do later next wek. Will keep you informed.
Cees van Kempen
Old October 18th, 2014, 01:41 PM   #22
My solution is heating - not over-heating. The plastic is warm but not hot - there is a built in over heating control in the LM 7809 so I am not afraid. But this solution with a cable ready for use is smart and not expensive so it will be fine. I would have bought it too if I had known it existed!
