What to give to TV at DVinfo.net
Old March 6th, 2009, 11:43 AM   #1
What to give to TV
Hi,
I have to give to the TV the Finnal Master TAPE and SD tape. I record in P2 720p and I edit in Premier, so I have the MXF staff.
They want HD CAM. Have you transfer your work to HDCAM 1920/1080? We are going to transfer in After Effects the MXF to an uncompressed AVI and then we will send to a HDCAM tape. Has you ever tried that? We are going to do the same to transfer to Betacam Digital
Pablo Lozano is offline   Reply With Quote
Old March 8th, 2009, 05:46 AM   #2
Panasonic Broadcast
This is very simple. You need to know what the TV station needs. You will need to make a conversion from 720 to 1080i to make that HDCAM master tape. MAny NLEs have this built in and it is a rendered output, then once finised play out to trecord on tape. Same thing on the Standard def. Render out the SD and then play out to SD deck.
Perhaps someone can be more helpful if you identify which NLE system you operate, and which decks you have to record to.
Best,
Jan
Jan Crittenden Livingston
Panasonic Solutions Company, Product Manager for 3D and Handheld Cameras
Jan Crittenden Livingston is offline   Reply With Quote
Old March 9th, 2009, 12:02 PM   #3
Go Go Godzilla
Images: 15
Pablo,
Since you're editing on Premiere the best thing would be to post this question in that forum category, then you'll get answers from those who are using the same NLE as you are.
A quick search on Google and I came up with this on another forum:
Exporting to HDCam framerate : Adobe Premiere Pro
Your uncompressed AVI out to an HDCAM deck seems the most logical - once you do the framerate conversion.
Robert Lane is offline   Reply
