where to buy a spare component lead...or two at DVinfo.net
Old December 23rd, 2006, 06:47 AM   #1
I have only having one, especially as my cat really enjoys chewing on expensive leads much to her enjoyment!
Any links where i can buy one from?
Also does anyone else find the component socket/ lead is a bit loose on the camera?
Philip Bloom
Old December 23rd, 2006, 09:19 AM   #2
Go Go Godzilla
Images: 15
Phil,
The component connector has clips to help make a solid electrical connection but they are not designed to hold up the weight of the cable itself. As with any connection into the camera (with possible exception to the robust XLR's) you need strain-relief on all the cable inputs to prevent accidental disconnect and reduce the strain on the connector itself caused by the weight of the cable pulling it down.
Most are using cable ties on the HVX handle, others have an off-camera cable tie connected to their rail system. Either way, the name of the game is to not have the connector do all the work of holding up the cable AND making an electrical connection.
Many have complained about the component connector being weak and eventually failing over time; typically these same people are not using any strain-relief. Myself and other HVX shooters I know have been using the component cable - tied-off to the handle - reliably for over a year without the connector losing it's integrity.
As a point of reference, there isn't one cable on my rig that doesn't have some form of strain-relief, whether it be a cable tie or, simply wrapping it around an external peice of equipment thus preventing the connector from bearing the weight of the cable.
Old December 23rd, 2006, 09:39 AM   #3
Specialized Communications
Sorry Chris!
David Linetsky is offline   Reply With Quote
Old December 23rd, 2006, 12:36 PM   #4
Go Go Godzilla
Images: 15
Originally Posted by David Linetsky
...We do have the original and aftermarket cables available in several lengths.
David
Really?!! How long? Is it on the website? I'd love a long single component cable; right now I've mated the standard (and painfully short) HVX-component to a longer one using BNC/RCA adapters and I've never liked that solution.
Do you have a long cable with BNC on the other end? I'll order one now!! (laughs)
Old December 23rd, 2006, 02:25 PM   #5
Sorry Chris!
Old December 23rd, 2006, 04:28 PM   #6
Folks, please consider making your purchases from our DV Info Net site sponsors; when you give them your business, it helps us to keep this site running. Any of our full-line dealers such as B&H, etc. will have these component video cables in various lengths with either 3x BNC or RCA plugs at one end and a D-Terminal (I believe it's D4) at the other end... this connection is common to not only the HVX200 but also most of the major 3CCD HDV camcorders such as the Canon XL H1, XH A1 etc.
For Phil Bloom, our UK sponsor is Production Gear in Hertfordshire, and of course B&H ships worldwide. See our sponsors page for contact info and site links at http://www.dvinfo.net/sponsors -- thanks,
Old December 23rd, 2006, 05:48 PM   #7
Go Go Godzilla
Images: 15
Sorry, Chris. For some reason I always assumed Spec-Comm was one of the sponsors, which is why I openly asked for the biz.
Old December 23rd, 2006, 06:20 PM   #8
Go Go Godzilla
Images: 15
Originally Posted by Chris Hurd
...Any of our full-line dealers such as B&H, etc. will have these component video cables in various lengths with either 3x BNC or RCA plugs at one end and a D-Terminal (I believe it's D4) at the other end...
Actually, I've scoured the B&H and other's sites for this exact kind of cable and the only thing I've found is a cable from Canon; right D-type connector but it's just as short as the one Panny supplies. So if you've seen the exact cable we're looking for in the longer lengths somewhere, please share the link!
Robert Lane is offline   Reply
