Wide angle distortion at DVinfo.net
Old December 24th, 2006, 09:34 AM   #1
At times a wide angle pan shot in HD reveals a bit of distortion on a wide screen plasma tv. At certain spots it appears to temporarily stretch a portion of the shot. Is this normal.
William LiPera is offline   Reply With Quote
Old December 24th, 2006, 10:49 AM   #2
First check the widescreen mode of the plasma TV. Many plasmas feature a non-linear stretching mode that turns 4:3 into 16:9 by stretching the left and right sides more than the center (so faces won't look so fat). This mode on the TV would exhibit the symptoms you are seeing with panning shots.
Earl R. Thurston, Stargate Connections Inc.
Made with GY-HD100: The Container Adventures: The Rescue
Earl Thurston is offline   Reply With Quote
Old December 24th, 2006, 11:35 AM   #3
distortion
Thanks, that's probably it.
