SDXC can you record longer than 4gb/12 mins? at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
HD from Nikon D90, other still photo cams (except EOS 5D Mk. II, LUMIX GH1).
Old October 29th, 2010, 01:01 AM   #1
im going to be getting a sony a580 and am trying to find out if by using a SDXC card if you can record video longer than the normal using a SDHC card?
Dave Morgan is offline   Reply With Quote
Old October 29th, 2010, 04:39 AM   #2
I have the same question about the 550D / T2i.
SDXC cards with exFAT filesystem should be able to do this.
regards
Daniel
Daniel von Euw is offline   Reply With Quote
Old October 29th, 2010, 07:39 AM   #3
For cameras with a 4gig limit, you have to work around it. The firmware is deliberately crippled, there's nothing you can do to change it.
Kin Lau is offline   Reply With Quote
Old October 29th, 2010, 08:08 AM   #4
The 4gig limit is not a problem of a "crippled" firmware - its a filesystem issue.
SD, SDHC und CF Cards use filesystems that support only files up to 4gig.
SDXC cards use exFAT filesystem that support files with over 4gig.
regards
Daniel
Old October 29th, 2010, 08:21 AM   #5
regards
Daniel
Sorry, not true at all. My EX1 uses FAT and I can record continuously until the card is full. Whether that be 1 hour or 20. The camera simply closes one file, then opens a new one for writing. This has been done since tapeless cameras were brought on the market. The makers of these cameras have chosen not to implement this. It is a deliberate choice.
Old October 29th, 2010, 09:05 AM   #6
@Perrone Ford:
My and Dave's question was not why the sony or canon DSLR's do not beginn a new file after reaching the 4gig filesize.
Our question is what happend with SDXC cards?
Will the camera write also only 4gig files tought no technical reason exists?
Or will it write up to 29:59 min if the camera does not overheat?
Have someone testet this with SDXC cards?
regards
Daniel
Old October 29th, 2010, 09:37 AM   #7
It's a _design_ decision. After stated many times before, file spanning works _fine_, Canon and others simply _chose_ not to implement it due to EU tax laws. Simple as that.
My Canon HF100 and Panasonic GH1 both work fine with SDHC and FAT file systems, and there's no software record limit.
Old October 29th, 2010, 11:05 AM   #8
I knew that file spanning works fine and that it's a design decision to do it or not.
But with SDXC and exFAT you don't need file spanning to record more than 12 min and due to EU tax laws its allow to record up to 29:59 min.
So you knew from personal experience that also with SDXC cards the camera stop by 4gig filesize?
regards
Daniel
Old October 29th, 2010, 03:00 PM   #9
I don't think it matters if SDXC supports files larger than 4Gb, I can format sd card with NTFS, pop it into EX1, and it will have to re-format it to FAT in order to be able to record, so the question is if your camera will support other tha FAT FS.
I love this place!
Old November 13th, 2010, 10:48 PM   #10
There's a sensor heating issue also at play here.
The DSLRs aren't optimised for video shooting and so they tend to run hot when the mirror's up and they're essentially in live view/video mode.
So the 12 / 20 minute clip limits have to do with that too.
But also:
Looking at the D7000 with its overflow capability, like the EX1/3, there's theoretically no limit to the length of shot that's possible, regardless of file size. With the overflow, as soon as one card gets full, writing switches over to the other card. While that's happening, in theory you could pull the first card, insert a fresh one, and keep going.
In the EX1 or 3 that's exactly what happens, no matter if you have a 2GB card in or a 32GB card in.
You can take one continuous clip that spans several card-loads. But even though, like the EX1, the D7000 has two card capacity, you can't exceed the recording time limit on each clip.
In theory, the same would be possible for a DSLR. However, two things, 1) the sensor heating, as I mentioned above and 2) the fact that they didn't pay royalties for proper AVC aquisitiion (or whatever the video compression system is) means that they've essentially crippled or cut off the maximum recording times to the lengths they are now.
Not that this should be a problem, of course. How many people actually watch single shots that last for 12 minutes without a cut?
C
"The content, not the container."
Chris Leong is offline   Reply With Quote
Old November 13th, 2010, 10:59 PM   #11
C
You ever film a press panel? A speech? A conference presentation? I've filmed all three with no breaks for over 45 minutes. Occasionally over an hour which is why I went tapeless in 2004. MiniDV proved too short for the panels I was assigned to shoot.
Old November 14th, 2010, 06:46 PM   #12
I did an interview with my EX1 that lasted more than three hours. Definitely a shortcoming of DSLRs, that you can't do it.
Eric Pascarelli is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
