Help: On Camera Light for GL2 at DVinfo.net
Photon Management
Old January 22nd, 2004, 04:36 PM   #1
I just ordered my Canon GL2 today. In the near future I will be video taping my buddies wedding and reception. What kind of on-camera light should I buy to light interviews at the reception? It will be kind of dark but not completely. I could probably get video of the interviews but it would be poor. I am looking to spend around $300 maybe more or less. I've noticed that canon has both a 3watt and 10 watt light that will connect to the top of the camera. Is 3 or 10 watts enough in low light?
Any help would be greatly appreciated.
Jon
Jon Omiatek is offline   Reply With Quote
Old January 22nd, 2004, 07:15 PM   #2
Jon,
For close work 3-5 feet, in partially lit areas (receptions) you'd be surprised at how much light the little 3 watter will provide. Best part is that you're not blinding the guests and they feel more comfortable talking freely.
Rob Wilson is offline   Reply With Quote
Old January 23rd, 2004, 08:36 AM   #3
Thanks for the reply. I found a post online which tells you how to build a led camera light. No real instructions but a good point in the right direction. I will post a complete how to when I finished. I ordered the LED's last night.
Thanks again.
Jon
Old January 23rd, 2004, 08:42 AM   #4
Possible LED light you could use
http://ledmuseum.home.att.net/fusion.htm
Brighness levels:
HYPER BRIGHT: 38,600mcd
HIGH: 33,500mcd
AUTO-OFF: 28,400mcd
MEDIUM: 8,500mcd
LOW: 2,300mcd
The led lights I purchased are 8000mcd each. I was planning on using 24 leds and 48 leds depending on what level of light I need.
Jon
