Getting an ARRI Fresnel Wet? - Page 2 at DVinfo.net
Photon Management
Old January 14th, 2011, 10:07 PM   #16
Nice to hear and THANKS for the update ;).
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old January 18th, 2011, 10:32 AM   #17
Caleb
Glad to hear it worked out. With all respect to you and your gaffer I still do have to say that having worked as a lighting technician for 20 years on Canada's "wet" coast, you should have used a gfi (aka gfci). For future reference you can buy a plug and play 15 amp gfi at any decent hardware store. Light stands, c stands in particular can fail or get knocked over. Just saying this for future reference for you or others.
It may be interest to understand how a gfi works. It measures the difference in amperage between the hot and neutral of a circuit which should be the same. Any difference indicates some current is grounding off which in a wet environment could be through the water. The gfi has a threshold of .025 amps which is the minimum needed for electrocution.
Jase Tanner is offline   Reply
