are these cables interchangeable? at DVinfo.net
Photon Management
Old February 17th, 2012, 12:13 PM   #1
The first one's 6 ft, the second is 10 ft. Anything proprietary about the brand name cable?
http://www.bhphotovideo.com/c/product/653294-REG/Zylight_18_02006_DC_Power_Extension_Cable.html
10' DC extension 2.5mm power cord/cable CCTV extender on eBay!
Philip Fass is offline   Reply With Quote
Old February 17th, 2012, 09:37 PM   #2
Re: are these cables interchangeable?
Other than the Zylight being a 2.1mm plug and the one you linked being a 2.5mm...!!!
Actually, even if the latter was a 2.1mm, you have to be very carefully when dealing with these types of plugs. They have two specs that are critical, the OD and ID (outer and inner diameter), and they are generally only listed with the OD. So in the above example, the outside may fit but the inside may not, and it won't work.
I would contact Zylight and ask what the two specs are on their power connector, and then you can order a third party one if you prefer.
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
