Lighting Kit Recommendations for Mixed Use? - Page 2 at DVinfo.net
Photon Management
Old September 6th, 2006, 11:56 AM   #16
DVCreators.Net
Just ordered one of those Harbor Freight "dimmers" to give a try out. Sounds like it'll work great on a Lowel Pro light as a 250W seems to be a bit hot when back lighting a subject in a small area. The color temperature shift won't matter much on the back light as a lot of the time I like to throw a 1/4 CTO gel on anyway to warm things up.
Here's a video you might want to check out that we made real quick to show the difference between using standard overhead lights and then a Lowel DVcreator Kit. That's the Lowel Omni, Tota, and Pro in one small case. Check it out at http://dvgeartalk.com/
Guy Cochran
Guy Cochran is offline   Reply
