Faking Candlelight reflection on face ? - Page 2 at DVinfo.net
Photon Management
Old May 27th, 2007, 01:45 AM   #16
Hi,
Something else to try... Have candles made with a double wick. i.e. 2 wicks. This works well to increase the natural light level from a practical candle. If that's enough for the "wide shot" then you could add a bit of bounced light (with the correct color gel) for the close up.
On a recent episode of "The 4400" I had an actor in a mine shaft who's "ability" was to create fire with his hands. The FX guys rigged a butane jet to his finger to get real flame and I augmented it with my "scorpion" flashlight (with Full CTO Gel) bounced off some white paper. I just had to quickly shake the flash light to simulate the flame jittering. It worked well!
Simon Hunt
Gaffer
Simon Hunt is offline   Reply With Quote
Old May 27th, 2007, 06:36 AM   #17
Images: 32
Another way to fake fire/candelight is to shine the light through a cookie and move it gently back and forth. You can get a similar effect by using a gold reflector.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old May 28th, 2007, 09:25 PM   #18
I had to do a similar thing a few weeks ago, where some actors had to appear to be looking back at a car they've just torched.
We used a wooden pole with rags tied to the end of it with wire, soaked in parrafin. It was 3 feet away from the actors.
The still picture shows how it looked originally, and the attached WMV clip is a rough idea of what we did with it.
Seemed to work alright . . . .
"Well I was working on that Orchid Preservation Society website, but I got sort of bogged down with it . . ."
John Westbury is offline   Reply With Quote
Old June 1st, 2007, 11:43 AM   #19
Best candle/fire fake I've ever done:
I have one of those round pop-up reflectors; take it out of the case, but don't unfold it; makes a 1-foot(ish) wide circle of flexy silver. Hold it low, point a 6" fresnel at it (gel if needed) and flex/wiggle the reflector.
For campfires/fireplace, unfold the reflector & use the full size. Worked like a charm.
Michael Carter is offline   Reply With Quote
Old June 15th, 2007, 10:18 AM   #20
I like the combination of dimmers and reflectors. For big fires, you can use 2 or 3 lights with gels on them (pointed at the same direction), dimming each of them at a different speed.
Brian Posslenzny
http://www.CineVeraPictures.com
Brian Posslenzny is offline   Reply
