CAVision 2-Wheel Follow Focus Design Flaw ? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Remote Lens Controllers
Old June 19th, 2006, 09:39 PM   #1
I ordered the dual-wheel follow focus by CAVision for my Chroziel Mattebox/Rods. It seems that the second wheel does not clear the zoom grip on the lens. I have the stock lens and the wide angle and it doesn't clear either. I emailed CAVision about it but haven't gotten a response yet.
Is this a design flaw? Has anyone else experienced this? How about the dual-wheel Chroziel? Does it have the same issues?
Webb Pickersgill
Bassline Digital, LLC
Webb Pickersgill is offline   Reply With Quote
Old August 26th, 2006, 12:17 PM   #2
Was there ever an answer on this?
I am looking for a follow focus for the HD100 standard and wideangle lenses.
Which one works the best?
Which one works the best for a reasonable cost?
Chrosziel?
Petroff?
Cinetech?
Cavision?
Vocas?
Redrock?
Indifocus?
Does anyone have experience with follow focus units on the standard and wideangle lenses on the HD100?
Old August 26th, 2006, 12:57 PM   #3
Petroff Follow Focus
Hi Jack,
I have the Petroff follow focus and it works great with the wide lens but the gear won't reach the focus ring gear with the standard lens. It would work for the standard lens by putting the gear on the "outside" end of the shaft, but then focusing would be reversed.
we enjoyed meeting you and Julia yesterday!
Tip
Tip McPartland is offline   Reply With Quote
Old August 26th, 2006, 01:24 PM   #4
Originally Posted by Tip McPartland
Hi Jack,
Tip
Yes, Here, too!
And I will go over and look at the Petroff Mini Follow Focus. I don't want to buy one of these without trying it.
Old August 26th, 2006, 01:51 PM   #5
The Cinetech studio(duel wheel) follow focus works perfectly with the standard lens but it too is relatively tight to the zoom strap. You have to adjust the focus wheel downward slightly. My question is why buy a Cavision follow focus when you have a Chroziel matte box? If you have a Porsche why buy cheap tires?
Scott Harper is offline   Reply With Quote
Old August 26th, 2006, 02:09 PM   #6
Actually, I don't have a chrozsiel or any matte box yet. I am looking at different options, and then I will get something.
I looked at a chrozsiel matte box and don't like the heavy weight. I am looking at some lightweight alternatives for what I need.
I need a good, yet not over heavy or big, follow focus attachment. This seems to be the most critical item in that it must be slop free, must fit correctly, must work well.
From searching the forum, it seems that not a lot of people have experience with follow focus systems on the HD110... but I would like to get whatever info I can.
Old August 26th, 2006, 11:58 PM   #7
I wasn't referring to you, Jack. Anyway, as far as good follow focus and matte box combos go, check out an older(1 month or so)post where we discussed these things here on this site. Sorry I can't remember what we posted the title as but if you search matte box/follow focus you'll find it.
Old August 27th, 2006, 09:08 AM   #8
Moved from HD100 to Lens Controls
Chris Hurd is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Remote Lens Controllers
