SI-2K Mini in the Field - Page 2 at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old August 30th, 2009, 01:03 PM   #16
Try this one. Shot with a 200mm f2 Nikon prime. It was quite a challenge for Gavan O'Sullivan because he was having to aquire the aircraft on base leg whilst it was still a small target without an on-camera viewfinder, very much a testament to his camera skills.
FOX FEATHERWEIGHT TWENTYEIGHT SCN6 SHORTFIELD LANDING By Bob Hart On ExposureRoom
Old August 30th, 2009, 04:36 PM   #17
The green button is a start/stop and will work with the Mini but you need a splitter Y cable so it can plug into the power connector along with your power.
Rohan Dadswell is offline   Reply With Quote
Old August 30th, 2009, 05:57 PM   #18
Got it! Thanks Rohan
Alex Raskin is offline   Reply With Quote
Old August 30th, 2009, 06:15 PM   #19
Originally Posted by Alex Raskin View Post
I think mini jib on a sliding dolly should be fantastic. Will try shortly.
(Obviously not for running through the slums of Mumbai or anything....)
Tried, and here's the pic!
I hacked an 8ft jib (that i did not love) and made a 4ft microjib out of it. Since the weight is so light now, I also did not need more than 5Lb of counterweight.
All this mounted nicely on my DIY Igus-based slider.
Smooth-moves-o-rama! :)
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
