Lens Changes at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old July 3rd, 2007, 06:14 PM   #1
Lens Changes
Hello,
Is the SI2K meant to operate in a way where lenses are changed often?
My question is related to possible dust on the sensor.
With DSLRs, changing lenses too often can lead to needing to clean the sensor often as well.
How does the SI2K act in this regard?
Thank you
Old July 4th, 2007, 03:05 AM   #2
There was a discussion about this subject on CML. It seemed to conclude that cleaning the sensor on cameras like the SI 2K and RED will have to become a routine operation like checking the gate on a film camera.
Old July 4th, 2007, 06:14 AM   #3
Cleaning is not that big of a problem if the sensor is protected and was designed to be cleaned easily.
Old July 4th, 2007, 06:22 AM   #4
Yes, you can easily pull off the low-pass filter if you need access to the sensor itself. Cleaning that is a matter of using some good lens cleaning fluid on *dampened* (not wet) lens tissue.
Jason Rodriguez is offline   Reply With Quote
Old July 4th, 2007, 07:20 AM   #5
Hello Jason.
So the sensor cleaning is not as delicate as cleaning a DSLR sensor where a lot of people say not to even touch the sensor?
Old July 5th, 2007, 12:35 PM   #6
There's a piece of solid glass in front of the sensor itself . . . I'd still be very gentle, and only use somethign as soft as lens cleaning tissue and have it ONLY DAMP (so you don't drip anything), but it's not like touching the sensor is going to cause harm. I've cleaned the sensor itself many times and have had no issues.
Old July 7th, 2007, 12:57 PM   #7
for what it is worth, I've had to clean the sensor initially after receiving it (mine is a preproduction model that I got back in December), but I'm very pleased with the lack of dust since. It has undergone frequent lens changes on a dusty set without being covered (between lenses) for three weeks, and less rigorous shooting indoors and outdoors since, and I haven't had any dust return. Not sure why, but I'm quite pleased.
www.marsunited.com
Chris Lakes is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
