Voltage range A7s at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old March 25th, 2015, 01:30 PM   #1
Voltage range A7s
Hi
I am struggling to find the voltage range of the A7s, I know the batteries are 7.2v. Basically I have a V-mount plate and batteries that gives out 5v, 8v, and 12v, would the 8v work (not kill the camera)?
Rob
nicecatmedia.com
Rob Lloyd is offline   Reply With Quote
Old June 23rd, 2015, 09:00 PM   #2
Re: Voltage range A7s
I am running my A7s off of a Sony NP970 battery plate.
Some of those batteries charge up to over 8 volts.
All digital cameras have voltage regulators in them to compensate as the batteries run down.
I do not know what the upper limit might be on the A7s but will be trying a 9 volt external battery soon.
I keep remembering back to my $8,000 Kodak DC760.
It also had terrible batteries but really "came to life" when I hooked it up to a small Acid 12 volt battery.
Although the Sony is not performing noticeable better, there have been no problems and it is not running hot.
And, most/all cameras have thermal protection, so I think they would shut down before any damage occurred.
Yes I think 9 volts is not too much and 8 would be safe.
Roger Martin is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
