Best A7S settings for continous AF? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old August 18th, 2015, 04:06 PM   #1
I'll be shooting with the A7S and the 55mm 1.8 in daylight and I was wondering what is the best setting for continous AF. I mean, "center", "wide", etc...
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old August 21st, 2015, 10:29 AM   #2
Re: Best A7S settings for continous AF?
Wide unless you are close and zoomed in then try center. Wide caters for a good AF
Old August 21st, 2015, 01:58 PM   #3
Because I film mainly people I have continuous focus/flexible spot set, with the flexible spot set about a third down the frame which is OK for most faces - then when filming if I want to keep it locked at a set distance I just hold the shutter down to keep it from hunting - nice
I really want however to work out how to focus track a moving object - I think it can be done for stills but cannot see how to do it while filming :/
Peter Rush is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
