Recommend a good top light? at DVinfo.net
Old January 10th, 2008, 05:21 PM   #1
Hello all
I currently use an IDX X3 LED top light on my F350. It's okay, but I wonder if anyone could recommend a better, 'brighter' top light I could use.
I did a shoot recently and there were a couple of other camera crews doing the rounds, and I am sure they had much more powerful top lights. Makes like a little easier shooting in low light. I think the IXD X3 has an equivalent of a 35 watt bulb.
I am going to the Broadcast Live show in London at the end of the month, probably the best place to get a new one. I am also going to bring along my f350 and ask a Sony guy to give it the latest firmware upgrade and I am very unsure how to do it!
Sparky - www.sparkymedia.net
Mark McCarthy is offline   Reply With Quote
Old January 10th, 2008, 05:45 PM   #2
Just doing a little more research on this and the
anton bauer ultralight 2 seems to be an ideal solution ,using the 50 watt bulb with dimmer and a softbox.
Does anyone use this set up with their 350? Can this light plug straight into the camera?
Thanks again
sparky
Old January 11th, 2008, 01:10 AM   #3
Images: 1
Originally Posted by Mark McCarthy View Post
the anton bauer ultralight 2 seems to be an ideal solution ,using the 50 watt bulb with dimmer and a softbox.
No it can't. If you use the dimmer, it won't run from the D-tap on the camera body. I have this very setup on my F350 and I am running from the d-tap on the AB adapter plate at the rear. The UL2 is nice for easy lamp change.
-gb-
Old January 11th, 2008, 07:10 AM   #4
I also have the AB Ultralight 2. For me it works great.
Power comes from d-tap on the ab-plate.
Changing bulbs is really easy and quick as well.
Emanuel Altenburger is offline   Reply With Quote
Old January 11th, 2008, 08:40 AM   #5
I use the Ultralight2 as well and keep two heads in my kit, one bulbed at 25watts for scrums, and the other bulbed at 50watts for stand-ups, etc. The only negative about these lights is that they aren't focus-able, but they are light weight and quite effective for bringing up the colour of flesh tones and filling shadows under average indoor light.
I can only run my 50w using a Hytron140 battery, as the combined load of the camera and the light is too heavy for my Dionic 90. Both work fine off of the camera's power tap.
This system is pretty much the standard ENG rig around here.
Peter Newsom is offline   Reply With Quote
Old January 11th, 2008, 09:23 AM   #6
I'm also using an Anton Bauer Ultralight2. They are, like Greg said, very easy and quick to change with another head module. I have one head module with the Anton Bauer softbox and the other with a diffuser and dichroic filter. The bulbs are also very easy and fast to replace.
Ivan Snoeckx is offline   Reply With Quote
Old January 12th, 2008, 09:15 PM   #7
This is what we use for our 350s
lite panels, the 3200 flood
works fantastic, has a dimmer, doesn't get hot.. pricey however
http://www.s131567196.onlinehome.us/...minisystem.asp
Ryan Hollings is offline   Reply With Quote
Old January 13th, 2008, 07:56 AM   #8
Constructing a dimmer for your Anton Bauer® Ultralight2
If you are very handy and do not have two left hands, maybe you can build your own $25 dimmer for the Anton Bauer® Ultralight2.
Take a look at this link!
www.ctshooter.com/dimmer.html
