XD 330 Field Monitor - Page 2 at DVinfo.net
Old October 6th, 2006, 04:00 PM   #16
Originally Posted by Alister Chapman
I had a look a the boland website and if you look throught the specs the 8.4" HD monitor appears to only have a resolution of 450TVL which is pretty much useless for HD.
Hhmmmmm... I think that spec for 450TVL was for SD???
I read
High Res/Very Fine Pitch 1024x768
might be a good choice for 1/2 the $$ unless I'm mistaken on the rez
Brian Jansen is offline   Reply With Quote
Old October 6th, 2006, 10:21 PM   #17
DVi Contributor
there are at least 3 differant Marshal 7 inch HD monitors, HDSDI only, HD componite only and that combo unit that does several inputs. DON'T get the last one. Its like those all in one fax,scanner,copy machines. It does not do anything very well. We have several of each of the other two types and they work very well for the price range. For twice the money you can move up to the 9 ich panasonic, -waveform only- no vector. or for three times the money get the astro. or the leader.
Craig Chartier is offline   Reply With Quote
Old October 7th, 2006, 05:00 PM   #18
Originally Posted by Max Kaiser
Thanks! That's exactly what I did NOT know. So, i guess with the 330 I'll need to use the component cables. Bummer as this will be a lot more cable weight, etc.
These look pretty lightweight
http://www.markertek.com/Product.asp...&search=0&off=
Bill Weaver is offline   Reply With Quote
Old October 9th, 2006, 04:17 PM   #19
Thanks guys, for all the messages. I think I'm gonna go with the Marshall as a first step, seeing as a number of people say it is alright. Mostly, I want to use it for framing, etc. And, I love the way the batteries mount right on the back - that is quite handy.
Max Kaiser
Director, Hand Crank Films
http://www.handcrankfilms.com
Max Kaiser is offline   Reply
