XD 330 Field Monitor at DVinfo.net
Old October 3rd, 2006, 10:44 AM   #1
Does anyone out there with a 330 have any suggestions for an inexpensive (relatively) AC/DC HD LCD field monitor? Also, what outputs do you use for this ? Since there is no SDI, do you have to use component, or can you use the composite out of the rear of the camera?
Max
Max Kaiser
Director, Hand Crank Films
http://www.handcrankfilms.com
Max Kaiser is offline   Reply With Quote
Old October 5th, 2006, 03:11 PM   #2
Hmm. No takers.
Well, I've done some research and looks like the Marshall 7" would fit the bill, and even use my existing batteries for power. I'm still just not sure about the composite output on the back of the camera. Will this be HD, or SD?
Max
Max Kaiser
Old October 5th, 2006, 04:14 PM   #3
Composite is always SD only.
There's no such thing as a composite HD signal.
My Work: nateweaver.net
Old October 5th, 2006, 04:20 PM   #4
Thanks! That's exactly what I did NOT know. So, i guess with the 330 I'll need to use the component cables. Bummer as this will be a lot more cable weight, etc.
Thanks very much for the info.
Max Kaiser
Old October 5th, 2006, 04:28 PM   #5
There's lightweight component cables available, you just have to hunt them down. I know what you're talking about though...not wanting to use something from Comprehensive or the like because it'll be a beast.
You should PM Charles Papert, Steadicam guys like him are always interested in lightweight, flexible cables and usually know where to get them made.
Old October 5th, 2006, 05:44 PM   #6
I have the Marshall HD field monitor and feed it HD-SDI from the camera. It mounts on the camera hot shoe. I have the 350 though. Doesn't the 330 have HD-SDI out?
Dan Brazda is offline   Reply With Quote
Old October 5th, 2006, 05:54 PM   #7
Nope. Component and composite only.
Old October 5th, 2006, 08:12 PM   #8
Hi Dan,
Which Marshall are you using? How is it for focus and outside usage?
I am considering a LCD for the 330 and just found this company.
Can anyone comment on these LCD's?
http://www.bolandcom.com/
Brian Jansen is offline   Reply With Quote
Old October 6th, 2006, 01:47 AM   #9
I had a look a the boland website and if you look throught the specs the 8.4" HD monitor appears to only have a resolution of 450TVL which is pretty much useless for HD.
Old October 6th, 2006, 07:30 AM   #10
Originally Posted by Brian Jansen
Hi Dan,
We're not happy with the Marshal V-R65P-HD. A lot of nice features and it looks great on paper (even though it's an HD monitor that is only 800 x 480) but we can't get it anywhere even close to our reference monitor in the studio with regard to brightness/contrast/saturation...etc... I'd love it if Sony or someone else out there had something better. Anyone else know of a good HD, lightweight field monitor?
Old October 6th, 2006, 07:44 AM   #11
Well...
Sony LMD-9050
Panasonic BT-LH900
ERG EV-85
Astro WM-3004
Astro DM-3008
Plan on about $4000 for any of these.
Old October 6th, 2006, 09:56 AM   #12
One of the few things I like about the Marshal is that it is 16 x 9. Any others like that out there that have better colorimetry? I know the 4 x 3 ones are switchable or have 16 x 9 frame markers but I prefer the true 16 x 9 types.
Old October 6th, 2006, 12:20 PM   #13
You seem to have described yourself right into the Astro monitors.
Old October 6th, 2006, 01:35 PM   #14
Pansonic field monitor
Hi Max,
Heard you went w/ the 330 -- congrats. From the same vendor, we purchased and are using a Panasonic BT-LH1700W for a location monitor w/ our 350. Waaaay bigger/heavier than a Marshall, but you can actually learn to trust what you see on the screen, and it has a built-in waveform/v-scope for additional monitoring. Street price under $3K, and it displays HD detail not visible w/ lesser lcd monitors.
Keith
Keith Rollinson is offline   Reply With Quote
Old October 6th, 2006, 02:19 PM   #15
The 7 inch Marshal has worked well for us.
Small enough to mount on the camera, but I've been using it on an old still cam tripod which my grip uses to back-seat focus assist/ comp.
We also use rca component cables and leave the connectors on the 330 and monitor for quicker set-up and to avoid any cable-tripping/ camera crashing disasters.
You'll like the 330. Congratulations.
http://www.dutchrall.com
Dutch Rall is offline   Reply
