24p Output at DVinfo.net
Old October 12th, 2006, 11:30 PM   #1
24p Output
I'm about to start a major multiple year project in 108024p on my 330.
I'm assuming this will do fine re: HD or SD DVD, as Compressor will transform it itno any file I need.
BUT ---
If I ever need to output this for broadcast, will I have trouble doing so in this format?
Is is just a matter of having proper output card on MAC?
Editing system: Final Cut
Thanks ahead of time
BW
Bill Weaver is offline   Reply With Quote
Old October 13th, 2006, 11:33 AM   #2
Telecam Films
You'll be fine... Also, keep in mind that the Sony XDCAM HD decks have built-in frame rate conversion capabilities on the HD-SDI output. A disk shot at 23.98 can be output as 23.98 or 59.94 with pull down. That gives you a choice of project frame rate setting when editing. Note that as far as now, this only applies to editing using the HD-SDI output on the deck. If you edit in FAM mode (MXF file transfer), the frame rate of the transferred clips can only be the one they were originally shot at.
Thierry.
BUT ---
BW
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old October 13th, 2006, 12:59 PM   #3
Thierry.
I will be using FAM mode. So does this mean I look around for a Kona or something like that when time to post?
Old October 14th, 2006, 04:53 PM   #4
interesting.... BTW, I have the 330. Doe's the component output do the pull down automaticly on playback in 24p? AND.. when shooting in 24p mode, is it best to use a shutter speed of 48?
Brian Jansen is offline   Reply With Quote
Old October 14th, 2006, 05:25 PM   #5
Generally, yes. Since you would assumedly be delivery on some flavor of Beta, or HDCAM, or D5, you would be relying on a Decklink or Kona card as an interface to that deck anyway.
Both the Decklink cards and the Konas will do necessary real-time conversions for you to get to most tape formats.
My Work: nateweaver.net
Old October 14th, 2006, 05:29 PM   #6
Yes. All analog component signals are always either 29.97 interlaced, or 59.94 progressive (some Panasonic 720p gear).
If you're trying to not draw attention to the shutter speed, then yes, 1/48th is the most "normal" shutter speed. Film cameras shooting 24fps generally have that shutter speed as default...and what most of us have seen our entire lives.
Old October 14th, 2006, 06:06 PM   #7
thanks Nate!!
Old October 14th, 2006, 11:22 PM   #8
Yes...
Thanks so much for the great input. I can breathe easier. I am having to make quick decisions on a long range project, which involves a university as well as one of Canada's most beloved wildlife artists. The film feel just seemed to fit the situation perfectly.
Most of this work will be ouput to SD DVD for near future, and FCP treats the 24p very nicely in that conversion.
Bill Weaver
Across Borders Media / Media that Matters
