Shoot 4:3 project in SD or HD? at DVinfo.net
Old April 12th, 2007, 10:43 AM   #1
Hello,
I´ll be shooting an SD (4:3) job next week. I will edit the project myself. What do you think ..... is it best to record DVCAM 4:3 straight away or should I record HD and crop the brought in material to 4:3 in post? I was thinking of shooting the whole project SD 4:3 as this material won´t be used in an HD environment anyway. So far I´ve just done SD 16:9 shoots, which I all did in HD and downconverted it later as I thought that I might have to use this material again. So it made sense for me to shoot in HD.
But anyway, I guess there´s always an advantage to shoot in HD. You could still use the "bigger" HD image to zoom in slightly in post etc, right?
Emanuel Altenburger is offline   Reply With Quote
Old April 12th, 2007, 12:17 PM   #2
HD downconverted to a high-end SD format will always look better, even if the downconvert is an internal software thing. The short reason why is "oversampling".
Just make sure you do it to something better than DV, i.e. DV50, or 4:2:2 uncompressed.
People shoot HDCAM and Varicam to downconvert to Digibeta everyday because it looks better, it's been standard procedure for years in some circles.
When I do it, I bring in the HD mdia, run a Compressor preset on it overnight, and edit the next day.
My Work: nateweaver.net
Old April 12th, 2007, 12:36 PM   #3
Nate,
thanks a lot for the info. This definitely makes sense. And ... it´s what I assumed.
As I said I´ve done several 16:9 SD shoots with my new F350. I´ve always shot in HD and downconverted afterwards. So I´ll also do it 4:3. Thanks again!
Old April 12th, 2007, 12:46 PM   #4
If you can easily crop from HD to SD without bogging down your editing process, then shooting HD will give you more options both now and later. But do a quick test first to see how this workflow is going to affect your ability to get the work done: if it's problematic with your current hardware/software setup then consider shooting in the delivery format. I try to shoot everything in HD now but will occasionally shoot 4:3 SD for production simplicity.
Old April 12th, 2007, 01:08 PM   #5
Images: 1
I like to shoot in HD HQ and if I need SD 4:3, I let the camera do the down convert and crop for me. The disadvantage to that is you end up working in AV/C mode and taking the usual 1:1 time ratio for ingest. But even that ratio is tempered by the ability to rough cut in the camera to a clip list and then feed the cliplist out the AV/C mode.
Of course, this also takes you to DVCAM and its 4:1:1 subsampling but that never stopped anyone from using DSR500/570 cameras. You can yield some nice results if you start with a high quality camera head, and the footage doesn't require much post processing (ie: ENG use)
Having that HD master is a good thing because it leaves all options on the table. The big advantage to actually shooting DVCAM mode natively is the extra time you get on the disc. And the smaller size proxy files allow for even easier FTP to a news bureau.
Is this a great system or what? (grin)
-gb-
Old April 12th, 2007, 01:29 PM   #6
It is a wonderful system indeed. So many options are available.
It´s not ENG but I will have to edit the project quite fast. I´ll be shooting for a few days and usually get quite a lot of footage with this sort of project. So for me the HD route downconverting the material I need (with the help of the clip list) and ingesting AV/C sounds like the best way for me and this project. Thanks a lot for that input, Greg.
BTW.... I did have some issues with xdcam writeback and Avid. Now with version 1.6 everything´s fine again.
Old April 13th, 2007, 11:35 AM   #7
Originally Posted by Emanuel Altenburger View Post
Nate,
Emanuel,
I've had problems converting HD 60i footage to 480i when using software solutions. So beware. Even using Compressor's best preset, you will get some softening of horizontal details. If I had to use software, Sorenson Squeeze actually looked the best ;-) But...
The best downconverstion I've used is either from the Camera (as Greg B suggested) or using the AJA Kona LHe. The results are spectacular every time with no softening of horizontal detail/lines and the shots definitely look sharper than if it were shot on SD in the first place.
best regards
Greg Penetrante is offline   Reply With Quote
Old April 13th, 2007, 06:55 PM   #8
Images: 1
And don't forget you have a choice of low, med, high detail for the in-camera downconversion to SD.
-gb-
Old April 14th, 2007, 11:26 PM   #9
If I shoot & edit in HD 1080i 60, what's the best way to downconvert using FCP & Compressor. I've looked for presets but can't find any that make sense.
Also, where do I setup the side cropping(or center cut)?
I own AJA Kona LHe, but don't want to playout to tape, then ingest from tape to make a SD DVD-R for distribution.
Richard Lesser
Producer, Cameraman, Editor
F350 • FCP • Media 100
Richard Lesser is offline   Reply With Quote
Old April 15th, 2007, 01:04 AM   #10
Images: 1
The good thing here, Richard is that you have left yourself options. You can go down to a 4:2:2 codec or even SD uncompressed if you are going to do a lot of post processing.
I presume from your statement that you meant downconvert to SD, but you can easily downconvert to 720P as well. Nate W. has done it with great results.
-gb-
Old April 16th, 2007, 06:19 PM   #11
Yes Greg, I'd like to take the HD 1080i FCP sequence and get it to SD DVD 4:3.
The steps would be from FCP to Compressor to DVDSP. But, I don't know
what to setup in compressor to down convert to 480i with the proper
side cut or center cut that gets me from 16:9 to 4:3.
"If I knew as much as Nate Weaver I'd be retired by now."
Richard Lesser
Old April 24th, 2007, 03:57 PM   #12
HD 1080 footage to 4:3 FCP timeline
I am trying to downconvert footage shot with the XDCAM at 1080 to work with an existing 4:3 project without getting letterbox. Is there a way to do this in Compressor? I too, would like to crop but don't see how to do this.
Warren Gentry
Warren Gentry is offline   Reply With Quote
Old April 25th, 2007, 10:04 AM   #13
Images: 1
Richard, Warren,
You'll need to set output frame size to 854x480 and crop 67 pixels from left and right side. This will yield a 720x480 (4:3) output file. I just tried it using MPEG Streamclip with DVCPRO50 (4:2:2 color) as the compressor.
You can use Compressor, but you'll have to roll your own preset. Start with the new default template and use the inspector to adjust. There's a tab in the inspector window labeled 'geometry'. This is where you set frame size and cropping.
-gb-
Old April 26th, 2007, 04:04 PM   #14
Originally Posted by Greg Boston View Post
Richard, Warren,
-gb-
Greg,
The steps for me would then be:
1) Create Quicktime ref movie out of FCP
2) Import into Compressor
3) Setup Compressor template using 854x480 output frame size & Cropping
4) For output to DVD use my typical Mpeg2 setting?
Richard Lesser
Old April 26th, 2007, 04:21 PM   #15
You don't have to specify a different frame size in Compressor to get the side crop.
Just go with 720x480 as always, and tell it to crop 160 from right and left.
Shoot 4:3 project in SD or HD?-picture-1.png   Shoot 4:3 project in SD or HD?-picture-2.png
Nate Weaver is offline   Reply
