Transfer HDV Footage via SD Camera at DVinfo.net
Old February 8th, 2011, 05:46 AM   #1
Anyone know if I can transfer A1U HDV footage (mini DV tape) to a SD Sony PC 1000 and capture in Adobe CS4?
Michael LaFortune
ArcturusProductions.com
Michael LaFortune is offline   Reply With Quote
Old February 8th, 2011, 07:40 AM   #2
I think the a1u can down convert HD to SD, so perhaps you can eliminate step 2 ( going to the SD Cam) and export directly to PC. The Sony HD1000U has a down convert button, I am pretty sure the A1U has one as well.
Noel Lising
Noel Lising is offline   Reply With Quote
Old February 8th, 2011, 07:54 AM   #3
Part of the problem is the footage is already shot in HDV. I want to send just the tapes to another state but they only have a Sony SD 1000 to upload and capture the footage in Adobe CS4. I prefer to keep it in the HDV format since it will be projected on a wide screen and used in a presentation.
Thanks for the feedback.
Michael LaFortune
Old February 8th, 2011, 07:59 AM   #4
Can't do that. You need an HDV deck or camera to play/transfert HDV material.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old February 8th, 2011, 08:02 AM   #5
That's what I thought but wasn't hoping for.
Thanks Jean-Philippe for the reply.
Michael LaFortune
Old February 8th, 2011, 08:03 AM   #6
Or you can capture the HD footage yourself (assuming you have the PC/Mac), dump the files to an external hard drive and send it to your client. 1tb hard drives are less than a $ 100 right now, cheaper than renting a deck in my opinion.
Noel Lising
Old February 8th, 2011, 08:06 AM   #7
That was also one of my other options I was considering.
Thanks Noel.
Michael LaFortune
