Telephoto Lens at DVinfo.net
Old September 24th, 2006, 06:58 PM   #1
Telephoto Lens
There has been a lot of good talk on the forum about the Sony WA lens but is anyone using a telephoto? Which one are people using? The sony brand or others?
John Dombrowski is offline   Reply With Quote
Old October 1st, 2006, 06:45 PM   #2
Telephoto VCL-HG2037Y
I just got back from a trip to the mountains and used the above lens.
I liked it fine... be aware you cannot zoom out all the way, as it looks like a "periscope" view (like you see on submarine movies) at wide.
Also is heavy... but I was able to shoot elk at very low light (dusk) - 200m away. Granted it was not Nat'l Geo quality, but I could not get any pics with any digital camera - too dark. I was quite impressed I was able to get anything at all, as all I could see with my naked eye was tan bodies moving. I saw the bull elk's antlers and dark mane clearly w/ this lens.
Also can get very tight shots of mountain tops. I was afraid when I left I didn't "have enough zoom," but it appeared this was sufficient for my needs (amateur).
A stable platform is critical - I stopped extending the "skinny" legs on my tripod, as the (substantial) wind would cause too much camera shake. Also turn off image stabilizer for clearer shot.
James Harring is offline   Reply With Quote
Old October 4th, 2006, 12:39 AM   #3
Another VCL-HG2037Y
-Good PQ
-i use it to limit DOF provided you shoot far away and zoom in
-use a stable tripod with a SMOOTH HEAD otherwise youlll be sure to notice the shakes
-it vignettes if you zoom all the way out!
James, do you ever use a Lens hood with the Tele lens? I'm considering a Cavision LH80, but i am unsure if it will fit on the Sony Tele Lens, if it does i'd be the step down ring and thus would be able to use the Lens hood on my Sony WA lens too.
dreaming hobbyist + storyteller
www.michaelywong.com
Michael Y Wong is offline   Reply With Quote
Old October 4th, 2006, 11:45 AM   #4
Results with the Sony HG-2037 2 x teleconverter
I am very satisfied with the Sony HG-2037 2 x teleconverter. I bought it together with the WA (HG-0737).
The teleconverter came with a very convenient rubber hood, which fits the converter quite well.
For results look at http://www.dewonderbron.nl/Hc_1_1.html.
Hans den Hertog
Hans
Hans_den_Hertog is offline   Reply With Quote
Old October 8th, 2006, 06:56 AM   #5
Originally Posted by Michael Y Wong
-Good PQ
I bought the Cavision LH77 for the wideangle. I sometimes just used the ring part of it so I could mount the polarizer, skipping the hood. I will say, I was always worried about the thing coming loose and breaking my $120 polarizer on a rock. (never did) Didn't have that much confidence in how securely it attaches. A bit of duct tape greatly increased my confidence though.
I use the included Sony lenshood for the tele extensively. I didn't have occasion to require a polarizer, etc using this lens, though it would be nice to have this option. Again, duct tape helps here too.
I will e-mail cavision direct as to compatibility, they're very helpful. Will post their reply.
Old October 9th, 2006, 09:31 PM   #6
Re:
Thank you very much Peter!
Old October 10th, 2006, 05:45 PM   #7
Reply from CAVision
According to the specifications the VCL-HG2037Y has an 81mm front diameter. Our LH80 lens hood will not fit on it because it has a solid circular back mount of 80mm diameter.
Regards,
Bernie Koth-Kappus
Cavision Enterprises Ltd.
Hmm, if I get the pocketknife out an do a little scraping.... <g> --Jim
Old October 10th, 2006, 10:57 PM   #8
Thank you Jim (I have NO IDEA why i called you peter in the other post)!
IF you ask me tho the Sony Tele Lens has a 79-80 mm diamter when I meassure with different rulers/tapes... i think I will get the 80 and scrape if needed!
