Low Battery reduces performance? at DVinfo.net
Old July 7th, 2007, 12:00 PM   #1
On my Sony HDC-HR3, my battery was getting low. Then I notice the light seems to look bad. I keep filming. Then I change battery. All sudden, the subject look well lit again. Does battery if getting low have affect on look of the video?
Seems very strange. I know with still cameras, whether the battery is low or about to die, the last shot will still look fine. Different with video? thanks.
Kevin Carter is offline   Reply With Quote
Old July 8th, 2007, 07:07 PM   #2
very unlikely to have any effect. it either works or it doesn't. i dont think there is a grey area.
Mauritius Seeger is offline   Reply With Quote
Old July 8th, 2007, 08:22 PM   #3
thats would I would think, but I swear I was seeing horrid low light, changed batteries and everything then looked bright and nice.
Old July 8th, 2007, 09:39 PM   #4
I'm thinking that you had some settings that weren't optimal for low light, like exposure or something else, and then when you shut it down and changed batteries, it cleared those settings.
Chris Harris is offline   Reply With Quote
Old July 9th, 2007, 12:06 AM   #5
If you're relying on the LCD, there's a good chance that the camera reduces power to it as the battery declines as it's a big power drain - my laptop drops significantly on battery power automatically for instance... and dims further if the battery gets low...
Just a theory - did the tape show the same phenomenon?
Old July 9th, 2007, 10:42 AM   #6
hmmm
Chris, I am set to auto for everything pretty much.
Dave:
is that it? I mean I am looking at the LCD to see what's up. Have not looked at tape yet, but thanks for pointing it out. So if the tape does not show the drop off, then it was indeed the battery just not powering the LCD....
Old July 9th, 2007, 11:14 AM   #7
Hi Kevin -
It's a guess, but I know my HC7s came "factory" with the LCD set VERY low - making the camera look much worse than it actually was - once I adjusted it, I get a much better view of what the camera is capturing - I franky think this is why some of the early reviews of the camera were less than stellar...
I think the idea is that if you can reduce battery drain with an "acceptable" reduction in power to one high drain subsystem, you get much "better" battery life - thinking the user would rather have a few extra minutes of use over a "full power" display... not sure about that tradeoff, but it makes some sense to power off less "critical" systems to maintain the primary function for a bit longer.
Old July 9th, 2007, 06:27 PM   #8
thanks for tip Dave: I'll check and report back, but it makes sense. Pretty bizarre to witness, as a still photographer by trade, it was really strange to see.
