Best Replacement V1 Mic Query at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old October 29th, 2007, 09:00 AM   #1
Looking for some suggestions for a quality replacement mic can substitute for the standard V1 mic (which I find too weak).
What do people suggest? Not looking to spend more than £200 ideally.
Is the Rode NTG2 good enough?
Deniz Ahmet is offline   Reply With Quote
Old October 29th, 2007, 09:06 AM   #2
You may want to post this in the audio section of the website. Or at least do some research there, because there's already a ton of great advice there.
They'll also help you figure out whether a shotgun mic is the best mic to suit your needs. So when you post there, tell them what you'll be using it for. Personally, I prefer hypercardiods to shotguns as I'm recording indoors more often than I'm recording outdoors.
Craig Irving is offline   Reply With Quote
Old October 29th, 2007, 01:19 PM   #3
Ntg-1
Since the V1 has phantom power you probably shouldn't get the NTG-2 which has space for a AA battery, and this makes the NTG-2 very bulky.
Get the NTG-1 which is much more compact unless you plan on also using it on cameras without phantom power such as the Canon HV20.
Rode makes great and very cost-effective mics, so the NTG-1 is a great choice.
Tip McPartland
Tip McPartland is offline   Reply
