Video is on the tape, but won't play back at DVinfo.net
Old January 28th, 2009, 10:48 AM   #1
I have a single tape that I shot yesterday that my FX1 will not play back. The tape doesn't jam, it runs fine, but no video plays back throughout the entire tape. The video is on the tape, I can see it when I fast-forward or rewind the tape during playback. However, during straight playback, no video/audio shows up on the LCD nor can be captured. The timecode counter is running, so TC data is OK.
Three other tapes I shot yesterday work just fine.
Dan Robinson is offline   Reply With Quote
Old January 28th, 2009, 03:03 PM   #2
Don't know for sure but try going between the SD and HD settings. See if anything plays back then.
Matthew Klos is offline   Reply With Quote
Old August 9th, 2010, 03:54 PM   #3
Did you ever solve this problem? Sprang up for me today and I'm puzzlified.
Kevin McRoberts is offline   Reply With Quote
Old August 9th, 2010, 04:51 PM   #4
Kevin: when was the last time you cleaned your heads?
Old August 11th, 2010, 07:37 AM   #5
About a week before it started happening.
Working on it yesterday, periodically got a C:31:23 error (T reel fault)... unless smaking some sense into it works, looks like its servicing time.
Old August 11th, 2010, 12:56 PM   #6
Try playing the tape back on a deck. The bigger units have better error correction which may find the correct data stream for proper playback. Camera probably needs servicing.
Old August 16th, 2010, 02:53 PM   #7
Dan, I had the same exact problem last year on one of my FX1's. I recorded a wedding ceremony and my second camera wouldn't record the video properly. I could only view it when I was eitehr fast forwarding or rewinding the tape. And I even tried to capture while fast forwarding and adjust in post. Couldn't capture any way possible.
I tried manually cleaning the tape heads, and that didn't fix the problem either.
Turned out that I had to have the a new tape assembly installed.
I sent it off to Armatos in NY, they replaced the assembly and worked fine ever since.
Cost me I think $350 for the replacement. Don't take my word for it as I don;t exactly remember since it was over a year ago.
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply
