Sony HDR-FX1 with P+S mini35 Image Converter - Page 4 at DVinfo.net
Old March 7th, 2005, 04:43 AM   #46
As the clip seems to be on heavy rotation here I just got it complete from MTV.. however the image quality (too much compression somewhere on the line) of MTV here via cable is so bad that you can't spot it as easily as previously on the other channel.
And I have to correct my previous post: sometimes it's not exactly in the same place but a little bit off center - could be due to image resizing/cropping in post or because the adapter/optics where moved sometimes?!
Soeren Mueller is offline   Reply With Quote
Old March 11th, 2005, 08:00 PM   #47
There's a new "edit" of the video available on his site with some set fotos in the background where on some occasions you can spot the cam setup! So I guess it's "officially" confirmed now. ;-P
http://www.hmanvisions.com/projects_fettesbrot.html
PS: No control/field monitor could be spotted!
Old April 15th, 2005, 01:12 AM   #48
rotating rings in the ground glass
hi guys, the rotating rings was dirth in the ground glass.
I could not see these rotating rings.
by the way ..
i shoot a new video on the sony FX1 with P+S Image Connverter.
http://www.ch71.de/clips/suchasurge_tag.mov
tom selleck is back !!!
chris
Christopher Haering is offline   Reply With Quote
Old April 15th, 2005, 07:53 AM   #49
Re: rotating rings in the ground glass
New video looks great Chris. Are you shooting interlaced then converting to progressive with software, or are you using the camera's frame mode?
Sean Woods is offline   Reply With Quote
Old April 15th, 2005, 08:56 AM   #50
Wow, thats realy good. some questions:
1) was light loss (due to PS) a problem
2) Shot interaced or progessive (cine modes?)
3) What kind of colour correction was used/ filters
4) What was done in post and was done during the shot.
Anhar
Anhar Miah is offline   Reply With Quote
Old April 15th, 2005, 08:58 AM   #51
camera frame mode
hi sean,
i use the camrera frame mode and the color correction on the DaVinci.
best regards
christopher häring
chris
Old April 16th, 2005, 08:07 AM   #52
Frame mode?
Can you explain further?
Does anyone know if its possible to rent a setup like this in London, UK?
Shealan Forshaw is offline   Reply With Quote
Old April 19th, 2005, 10:39 AM   #53
Hi Chris!
Again a very good looking clip! :-)
However I noticed that the colors on this one were not as saturated or high contrast as in the "Emanuela" video. But I reckon this was made with the intension of hm sort of emulating that 80s TV series kind a look?! And on some outdoor sky shots - especially with the heli against the sun - the sky is quite blown out... was this intended?
And one more question: the underwater shots! Did you do them using only the FX1 (or Z1?!) without the Mini35 in some underwater housing for the cam.. afaik there is nothing "standard" that would allow to use something like the FX1 + the Mini35 underwater.. or is there?! ;)
Thanks!!!
Cheers,
-Sören
Old April 19th, 2005, 01:32 PM   #54
Hi Chris,
Nice work!!!
Originally Posted by Christopher Haering
/.../color correction on the DaVinci.
What format was it posted in? Hdcam, dowgrade to digibeta?!? I would love to hear some more about the post production please.
/Fredrik
Fredrik Broman is offline   Reply With Quote
Old May 23rd, 2005, 12:12 PM   #55
I'm working the French Open out here in Paris for ESPN and while getting ready in my hotel room this morning I had MTV France on and sure enough, this video was playing. Looked FANTASTIC!!!
Here's a working link to the video BTW:
http://www.hmanvisions.com/clips_2005_1.html
Mike Tiffee is offline   Reply
