FX1 - Separate Audio Recording in different Channels at DVinfo.net
Old March 27th, 2005, 06:50 PM   #1
If I use "short shotgun mic" and "wirelss mic" at the same time, can I record "short shotgun" in channel 1 and record "wireless mic" in channel 2?
My assumption is that I used FX1 with "short shotgun mic & braket", "wireless mic", and "BeachTek DXA-4 or DXA-6"?
If my combination is incorret, please let me know. Or it's only possible in Z1U?
Thank you in advanced for any syggestions an comments.
Eric
Eric Fu is offline   Reply With Quote
Old March 27th, 2005, 10:25 PM   #2
Yes it will work like that with FX1
Khoi Pham
www.proeditproductions.com
Khoi Pham is offline   Reply With Quote
Old March 28th, 2005, 08:49 AM   #3
Khoi,
I have read the on-line manual and I did not see/find how to set the camera to do so, Do you mind telling me the detail steps about it. Thank you very much.
Eric
Old March 28th, 2005, 09:04 AM   #4
All you do is plug your BeachTek type device (I've got a DXA-4 and an FX1) into the mic jack on the camera and you're all set.
Bryan McCullough is offline   Reply With Quote
Old March 28th, 2005, 11:03 AM   #5
Great! I do understand now. The "Right" channel will be shotgun and "Left" channel will be the wireless.
Do you mind telling me what kind of shotgun you are using and what kind of bracket will fix in FX1 to hold shotgun? And one additional question is the FX1 low lights performance in dark enviroment like weddings? What kind of lights for FX1 in wedding events if you do weddings?
Thank you.
Eric
