I wouldn't think you could damage the FX1 by charging batteries on another camera, but I've never tried it myself. |
And since the only help I can get is this forum and Local one here is OZ, I'm not taking any chances. I think I should get some old Uni buddies together to join in on my Bussiness. But for now, I'm on my own. |
If the Z1 and the FX1 share the same housing, shouldnt the power units be the same? Or have they ALSO found another problem with the camera and fixed it in the Z1 and not tell us? YET, the Manual in Page 92, and 93 says that You can Use Info-Lithium [L] series batteries. No mention of limitations. *shrugs* Time to write a letter of dissatisfaction. |
Another recommendation, keep your cameras, whichever kind, off when changing batteries. When they're on and you put a fresh battery in, over time that can cause damage to the camera.
heath |
I'll throw in an idea - never charge your batteries in the camera and if you do , protect it like you do your computer with a sophisticated backups. Electicity at the pump is never constant. Spend the extra on a separate charger and , Leo , yes you can charge your batteries thru your old hi8 and , yes , it's compatible. Sony has just upgraded battery models . I've got a tr3300 that uses the same model and is interchangable. It'll be less painful to loose your old hi8 than a new fx1 ! Kurth
Leo - I was saying you can charge your new fx1 batteries in you hi8. It's just trickling a small voltage to your battery- I say it's compatible because I use the old model hi8 charging unit to charge my zs' batteries sometimes and it works perfectly. Using the hi8 camera should be the same. Now whether those older model L series batteries are incompatible with the fx/z - I'd recommend further research. I have put new L series batteries in my hi8 and they worked fine although I haven't done the reverse. I'd recommend simply purchasing at least one np-f970 and you can charge it using your old hi8 camera, or at least mine charges fine thru the old-style L series chargers made for hi8 cameras which , logic would say , would be charging them the same -Kurth.
G'day Boyd, Kurth,
Thanks for the input. I've actually decided to use my Hi8 to charge my batteries until I can get my hands on a Charger. It seems to work nicely, and I cant see anything wrong... for now. My Old Hi8 Camera is shot up anyway. It had a good 7 years of work on it, and I suddenly realised (after renting a FX1) that the onboard microphone had been shot for quite some time. (I never knew how good a basic mic could be. I just thought mics at that price were supposed to sound like that, but man! Anyway, still waiting on my FX1... comes in tomorrow. I bought the 970, which surprisingly enough could not fit on my Hi8 camera because of a metal loop that held onto the shoulder strap. I had to get my plyers and carefully snip off the loop so the huge battery could fit. (You couldnt put it in the back, because the loop was in the way. you had to slid it in through the top and then push it in.) Sony is crazy sometimes. (Or forces people to go crazy.) |
hahahah.... yea, I think I'm a little crazy. But the cam is broken anyway. If I posted my 3 minute video about car accidents, you'll notice just how bad my work was as of late because I just had so much trouble with it.
Its an old DCR-TRV130E PAL. And it does ok video, and sound, but since because I was a stupid young uni student amature, I never cleaned the heads, and never took much care of it. And most of the time, it gathered dust. I spend so much more time 'saving' my footage rather than editing it. And some of my mates say that the end product look and sounds ok, but thats after I slave over the computer trying to adjust and adjust till I go insane. Now with my recent purchase, I'm not taking any chances, and not making any shortcuts. And hopefully, the camera is the only thing I'll be throwing money at to solve my problems. (as when I got my 3 grand camcorder, back on the 90's I thought it answerd all my problems I had when I needed to make some docos.... It seems money dont make it work. (as I could have gotten a XM2 (GL1) for a few grand more, and actually learned how to use a pro cam...) I'm crazy man..... Crazy like a sane man stuck in a jazz club. |
Thanks, Wayne |
| All times are GMT -6. The time now is 02:32 PM. |
