Changes not allowed. Unplug i link cable???
I just bought my FX1 in May. Since this summer has had me running around I haven't had a chance to really use the camera until last night when my cousin asked me to record his comedy performance. I wanted to record on a standard mini-dv but down-convert from HDV to DV. When I went into the menu to do this (in Camera mode) and I selected the "on" for the convert button, the indicator light on the outside stayed on HDV and I saw this message in the menu: "changes not allowed. unplug i link cable".
What does this mean? I never even plugged an i link cable into it? Is this a problem? A known glitch? Is my camera defective? I proceeded by going further into the menu and selecting DV, which then changed the outside indicator light to DV. Is this how it is supposed to be done? |
Yep, we've all seen that ominous warning and wondered what it meant :-) The Z1 does the same thing (and also when you switch from PAL to NTSC). I think Sony was just covering themselves; they want you to be sure to unplug the firewire cable before changing modes. That message is displayed, as you noticed, regardless of whether a firewire cable is connected or not.
But there are reports of people blowing the firewire port on their FX1 and Z1 when connecting to a computer, so that's something you should be careful about (see: http://www.dvinfo.net/conf/showthread.php?t=64884 for example). To play it safe, turn both the camera and computer off before connecting or disconnecting them. But as long as nothing is connected to your camera I think it's safe to disregard the warning message. |
Ok. That seems to makes more sense. Thanks.
One more thing. When should the HDV or DV indicator lights be active? Switching the HDV-DV downconvert to "on" did not turn on the DV indicator light as someone else told me it would. However, (and obviously) the DV indicator light was activated when I switched the record mode from HDV to DV. Is this as it should be? |
