Tapes at DVinfo.net
Old January 11th, 2007, 04:27 AM   #1
Tapes
This has probably been asked before, but can a DV tape be used twice without damaging or putting dirt on the heads?
Allan Sealey is offline   Reply With Quote
Old January 11th, 2007, 06:55 AM   #2
Yes, though the more times you use it the more coating the tape will shed. Personally I normally record once, capture the whole tape to hard disk and then stick the tape in a safe place in case I ever need it again; they're so cheap these days there's little reason to re-use them.
Mark Grant is offline   Reply With Quote
Old January 14th, 2007, 04:12 AM   #3
I, on the other hand, view tapes in a different light completely. Like you I suspect I'd never ever set out on a shoot with untested kit - be it tripod, microphone, wide-angle converter ... or tape.
Just think - you're buying a tape that's a complex assembly of 28 parts, and you pay about a couple of dollars for each one, yet you expect that they'll all be 100% perfect? There is simply no way that this can happen. Even if 99.9% of those that get past end of line inspection (what's that worth at $2 per tape?) are indeed perfect - then that means that there's quite literally hundreds of tapes out there waiting to be bought that are faulty in some way.
Me? When I know a tape is good, runs perfectly and is dropout-free I can breathe again, safe in the knowledge that it's part of my tested kit. I've reused MiniDV tapes again and again, and I'm pretty sure the second and subsequent passes (when the microscopic impurities have been burnished down) give even greater reliability.
tom.
Old January 14th, 2007, 04:28 AM   #4
I hear what Tom is saying, but I sometimes re-used tapes where I was 100% confident I would never need the material recorded on it again. Then of course unseen circumstances occurred and I needed something I'd taped over. Big mistake and I will never do that again, so I'm like Mark - tape once then put them away for safe-keeping.
Even if you've backed up the contents on DVD or hard disk then I would still keep the tape as I'm wary of the archival quality of DVD or hard disk. Tape is cheap and so far (touch wood) I haven't had a faulty one (I've had cameras chew tapes a couple of times, but that's probably more likely to be a camera fault).
Paul Doherty is offline   Reply With Quote
Old January 17th, 2007, 02:04 PM   #5
tom.
Interesting point Tom. I never really thought of it that way. I have always used tapes once and then file them. Good argument to reuse though.
Jeff Rhode is offline   Reply With Quote
Old January 17th, 2007, 04:18 PM   #6
I buy tapes in packs of 5 or more. When I get them I number them. Forget names. Too much trouble. Numbers are easy and I just keep a chart of what I put on each numbered tape.
I would no more risk using a tape twice than I would go out on site with only one battery.
Paranoid? Me? No. Just because you are paranoid does not mean they are not out to get you!
Before I go out to shoot, I fast forward and rewind all of the tapes I am taking with me. I use an inexpensive DV camera to do that. Retensioning has always served me well.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old January 17th, 2007, 04:36 PM   #7
That's a good tip.
Old January 17th, 2007, 05:29 PM   #8
Indeed this is a very good practice!!!
Making Family Videos Not To Look Like Family Videos
Fred Foronda is offline   Reply
