Interval Recording/Time Lapse on Z1 - Page 2 at DVinfo.net
Old February 13th, 2007, 06:16 PM   #16
http://www.motionzonehd.com/auto_sea...?q=David Gould
http://www.motionzonehd.com/auto_sea...Chaosstock.com
http://www.motionzonehd.com/auto_sea...=Nick Graalman
All these shooters use DLSR to make timelapse videos.
Philip also has some clips on our site.
I shoot with a Nikon D200. Import image sequences into After Effects
and you can create what ever size or framerate HD file you want.....
I am also playing with bracketed timelapse exposures to create
HDR timelapse videos....very cool. Will post some when I get a chance.
Mike Schrengohst
dvd.pro@verizon.net
Mike Schrengohst is offline   Reply With Quote
Old February 15th, 2007, 05:27 AM   #17
Sarah try this:
download the DEMO version of DVRack
Turn ON the Z1 and connect to a PC (laptop or desktop)
Programme DVRack to record a frame every X seconds
In the end you have a DV file with the time-lapse properly done
You have 10 days to use it !
The present demo does not capture HD, only DV.
If you know someone that has the "old" demo version, this is NOT a problem...
Sincerely
Carlos Manuel is offline   Reply With Quote
Old February 19th, 2007, 10:39 PM   #18
One option would be to record to DV either on tape or to a laptop/hard disk recorder. Then import your DV file with ScLive, which has the ability to selectively pull 1 frame out of x frames, if I recall correctly...
Richard Iredale is offline   Reply
