Tally Light at DVinfo.net
Old May 8th, 2007, 08:47 AM   #1
Tally Light
Anyone know how to turn the tally light off on the Z1? I can't seem to locate the command in the menu's.
John
John Moon is offline   Reply With Quote
Old May 10th, 2007, 04:28 AM   #2
Images: 10
Hello,
I guess you mean the record light?
Go into the main menu and select the bottom option (looks like four squares) - don't forget you must be in Camera mode not VCR!
Then, it's the seventh option down - called REC LAMP
Duncan.
Old May 10th, 2007, 04:52 AM   #3
I actually wanted the front tally light OFF (to avoid subject reaction) and the back tally light ON (so I could see the camera running at a glance) - so I had to turn them both on, and stick a small square of black masking tape over the front one!
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply
