Just not the same - Page 4 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old December 26th, 2008, 05:28 AM   #46
Your camera only has an f/1.6 maximum aperture at maximum wide-angle. As soon as you start to zoom towards telephoto (even a bit) your lens loses speed such that at full tele it's only got an f/3.5 maximum.
So put it another way. You're filming in the gloom using f/1.6 and +6dB say. If you zoom to telephoto you only have f/3.5 as a max apererture, so the gain has to go up to +18dB (two stops) to compensate. If you don't allow the gain to increase you'll greatly under-expose your shot.
tom.
Old December 26th, 2008, 08:21 AM   #47
Thanks Tom. Very good info. I'll play with the cam with these things in mind.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
