Z5 I-link not available when using HVR-MRC1K ??? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old January 20th, 2009, 07:24 PM   #1
Is this correct? You cannot use a remote zoom control on the Z5 because the I-link is not useable at the same time the HVR-MRC1K is in use???
Bill Rankin
Bill Rankin is offline   Reply With Quote
Old January 20th, 2009, 08:08 PM   #2
I-link is firewire, as I understand, and you can't use it with memory module. Zoom control is connected via LANC jack, and you can use it.
Thank you.
Ilya Spektor is offline   Reply With Quote
Old January 20th, 2009, 08:14 PM   #3
I don't have this camera but have been watching it very carefully (read as lustfully.) The MRC1K unit connects via the firewire or "iLink" connection but the camera is equipped with LANC for connecting a controller. So the iLink is in use and cannot be accessed by another piece of equipment but a LANC controller could be used. hope that helps...
Sony | HVR-Z5U Professional HDV Camcorder | HVR-Z5U | B&H Photo
right, what spektor said - that's why you shouldn't get up to get a drink before hitting submit...someone will beat you to the post.
3x-HD1000u - Ikan 8000HD- custom i7 PC - Vegas Pro 13 and 11 64 bit - Premiere Pro CS4 - and a whole mess of other equipment...
Last edited by Bryan Daugherty; January 20th, 2009 at 08:16 PM. Reason: because I am too slow hitting submit...
Bryan Daugherty is offline   Reply With Quote
Old January 20th, 2009, 08:27 PM   #4
Thanks Bryan...actually, I already knew that...I just misread/misintrepreted (i.e. confused I link with Lanc).
Bill Rankin
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
