FX1000 and MRC1 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old January 23rd, 2009, 03:00 PM   #1
FX1000 and MRC1
There's a handy spot for the MRC1 on the Z5U but how does it "attach" to the FX1000?
Barron Thompson is offline   Reply With Quote
Old January 23rd, 2009, 06:48 PM   #2
There's an adapter plate & shoe mount.
Ken Ross is offline   Reply With Quote
Old January 23rd, 2009, 07:15 PM   #3
Functionality with MRC-1k?
I understand that the MRC-1k, attached to a Z-5 will record simultaneously (start-start) with the tape. Will it do the same with the FX-1000. Does anyone have any experiance with the MRC-1 and FX-1000 combo?
Also can the data on the SD card be played (previewed) back into the Z-5 or FX-1000?
Rod Bourne is offline   Reply With Quote
Old January 24th, 2009, 06:34 AM   #4
Here's an informative link:
Sony Product Detail Page - HVRMRC1K
Yes, the cold shoe adapter that comes with the unit secures it to the Fx1000. Thanks Ken!
Yes, the recorder will record simultaneously.
"The HVR-MRC1K captures the HDV™, DVCAM™, or DV stream output from the camcorder and allows users to record HDV/DVCAM/DV files to a standard CompactFlash® solid-state memory card, while simultaneously recording to tape."
And Yes, the data can be previewed.
Old January 24th, 2009, 03:18 PM   #5
Thanks for the response Brian.
I wonder If anyone reading this has the FX-1000 combined with the SD card unit and could comment on their experience with it...
Old January 24th, 2009, 05:49 PM   #6
Rod, it uses compact flash cards, not SD cards.
Greg Laves is offline   Reply With Quote
Old January 25th, 2009, 06:38 PM   #7
CF unit and FX1000
I wonder If anyone reading this has the FX-1000 combined with the SD card unit and could comment on their experience with it...[/QUOTE]
Hi Rod, I have just bought a FX1000 here in Australia and are also keen on the Compact Flash unit.
My understanding is that it will work via Firewire with the 1000 camera BUT WILL NOT automatically sync up with the rec/pause button on the camera.
This means you would have to manually press record on the CF unit meaning you could easily forget to pop it back in record.
mmm starting to think the Z5 may have been a better option.
Martin Duffy is offline   Reply With Quote
Old January 25th, 2009, 07:59 PM   #8
I think you've nailed it Martin. The FX1000 and MRC1 will record simultaneously with the tape but not in sync. So, yes, the buttons have to be pushed separately and they don't have the automatic SYNC capabilites that the Z5 and MRC1 does.
Old January 26th, 2009, 05:20 AM   #9
Thanks again
Looks like the fact that it won't auto sync record with the FX-1000 makes the selection of the Z5U a no brainer...
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
