Broken FX1000 clips - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old April 12th, 2009, 09:24 AM   #16
Jeff, did you try a head cleaner as a last resort? I'm also assuming that you've ensured your wireless setup isn't to blame...assuming you're using that kind of a setup during the dropout problems.
Wireless mikes can often be the culprit for dropouts.
Ken Ross is offline   Reply With Quote
Old April 12th, 2009, 10:39 AM   #17
Ken, I spoke too soon.
In the other incidents there was nothing to be done, however in this case I did get the original tape and upon playback everything was fine unlike the past incidents.
The first time I re-captured the footage I had 7 dropouts. I then did a cold boot of my PC, restarted Vegas, and had only one dropout. Go figure.
This incident was not a camera issue, so I was mistaken in this case.
Re: Tape head cleanerers, I don't use them. In this camera's case the serious incidents began with the first time I used it anyway.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
