Reverse telecine data recorder at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
Old June 26th, 2011, 07:13 AM   #1
I'm looking at the possibilies of getting a data recorder for my FX1000. Does anone know of one that will remove the pulldown from the 60i stream to get the 24p footage straight onto HHD, SSD or memory cards (preferably cards). It can be either firewire or HDMI.
I'm searching and finding nothing, my guess is that if such a device exists it would be of a cost that would make selling and upgrading the camera an alternative. But I'm hoping.
David.
David Walsh is offline   Reply With Quote
Old June 26th, 2011, 09:19 PM   #2
Re: Reverse telecine data recorder
The Convergent Design nanoFlash does reverse pulldown in real-time to CF cards. Just hook up your FX1000 via HDMI into the box, change the pulldown setting to be activated, and you're set.
You can also record in XDCAM HD 422 with this box.
http://www.bhphotovideo.com/c/product/711529-REG/Convergent_Design_CD_NF_001_BUNDLE_nanoFlash_Bundle.html
Old June 28th, 2011, 03:25 AM   #3
Thanks you very much, I'd found the nanoflash could do it, but couldn't confirm if it could through HDMI or just HD-SDI. But it's sitting at a price where upgrading the camera is a more tempting option.
David.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z5 / HDR-FX1000
