Re: How much longer to keep the Z5?
No need to worry.
If your three cams have been matching up well aready, you will not have any new problems by adding a Ninja recorder to one of them. I'm wondering if you have been capturing from HDV tape via the Matrox Mini? If so, you probably have been capturing via the Mini to a Matrox 1440 HDV format. That codec is what you get when you use the Mini, but you could just as well have captured via Firewire and gotten a standard HDV file. It makes no difference to the preset in PPRo. You can still do captures with the Mini from your other two cameras and mix that footage with the Ninja files and not need to make any changes to your PPro work-flow. In PPro CS 5.5 (and prior versions), the Matrox Mini is simply a display/monitoring device. You only use Matrox presets so that your timeline goes out to your external monitor. The timeline accepts whatever I've you put in it --- I had one with DV, HDV, AVCHD, XDCam, Cineform AVI, and Quicktime, footage. I've never tried ProRes but, in my experience, the Matrox preset is completely agnostic about the kind of video you put on the timeline. You do not have to convert anything. In terms of matching footage from HDV with Ninja files, the differing codecs will not make any practical difference in most situations. Camera settings and white balance are far more important. I regularly mix 1440x1080i HDV (from MRC units) with 24 mbps 1920x1080i AVCHD without a problem. (Well, I do spend some time making sure I have similar settings for say, the FX1000, NX5 and CX cams that I use). But the 1440 andd 1920 numbers only reflect differences in pixel shape. They make no practical difference for resolution or color in most situations. Adding a Ninja will not change this for you.. I generally use a 1920x1080i timeline preset and let CS 5.5 takes care of adjustments. And, when I say I mix HDV and AVCHD, I'm talking about multi-cam shoots with as many as seven cameras and venues as different as outdoor weddings and dance recitals in dark theaters. In theory, the greater color space with the Niinja could yield footgae that is enough sharper/cleaner etc. to be noticably different from footage recorded with lesser colorspace, and sometimes it can be distinct for the reasons that Jeff has pointed out. Mostly, though, a Ninja can make some editing easier --- for example, the more robust color space may give you more flexibility in matching with your other two cameras (as opposed to trying to make editing adjustments of the standard HDV footage to match the Ninja footage). But, as Adam and Leslie have pointed out, the differences to viewers are only likely to make a practical difference if you are editing for large-screen theatrical releases, green screening, doing heavy color grading (as opposed to simple matching between cams), and the like. This is not to suggest or imply that you should skip the Ninja. Tapeless recording has major advantages. (I use a mix of MRC-HDV cams and AVCHD cams and no longer shoot tape, at all). The Ninja can give you more robust images, too. The cost difference over an MRC is not large. If I did not already have MRC units, I probably would be getting Ninjas, myself. So, as a practical matter, you will not have to do anything different with your CS 5.5/Matrox Mini editing set-up except that you might want to use a Matrox HD 1920x1080i sequence preset rather than the HDV presets you have been using. I've found going the other way (using 1920 AVCHD in a 1440 sequence) sometimes makes for odd scaling in the the external monitor view from the Mini. This might just be a peculiarity my computer system, but it does not occur when I use a 1920 preset. |
nice summation jay ;-)
Thank you Jay West.
I have 2 Sony Z7U's and 1 Z5U. I have 2 MRC HDV recorders for the Z7U's. I think getting the Ninja would make everything tapeless and then I could also offer more robust codec for clients that want it. I would rather do this then getting another MRC unit. Now, I mostly shoot 1080 30P on the MRC's. Any issues with mixing the Ninja footage with the other cams this way? My understanding is that the HDMI output for both the Z7U and the Z5U is strictly 1080 60i. |
My admittedly hazy recollection is that the Ninja records what your camera shoots. The Z5 and Z7 record in 1080/30/p. The Ninja will record it. Try a search on "Sony Z5 + 1080/30p + ninja" and I think you'll find confirmation of this.
Hi guys,
Can I ask a question of the Ninja owners.... Has anyone had issues at loud venues with the hard drives stopping because of vibration errors due to the bass sound waves? I had a HDD camcorder that suffered terribly from this which made it all but unusable for concerts. I know SSD would be better, but kind of blows out the cost a bit. |
Does anyone have issues with Ninja portability?
How does the Ninja attach to a Z5 or 7 when working in a number of locations outside - is there a clip or velcro strap you can use? Is it durable when bumped or even dropped? Thanks |
Since nobody has responded to the questions about vibration resistance, mounting and portability, I'll offer my 2 pennies worth based on the little I know.
Some of this comes from having read through the manual for the Ninja when I looked at the possibility of getting one. Some of this comes from comparing footage shot with MRC-equipped FX1000 (the prosumer Z5) with that from an NX5 (the AVCHD version of the Z5). When it comes to comparing the Ninja with an MRC for a Z5, here's how I respond to the questions that Gerald and Chirs posed. (a) Mounting: you can mount the Ninja into the tripod socket on the bottom of the camera. It is similar to to the way you insert an XLR adapter unit between tripod and camera. The Ninja is vertical so you can see the screen, Atomos said you also can mount a Ninja topside to an accessory shoe. I do not recall if Atomos sells the shoe-bracket-adapters, so check the web site. The touch screen has (I think) a single record button which will seems less awkward that doing tapeless recording with an MRC. When going tapeless with and MRC (no tape in the carriage), you have to press two buttons (record and play) much like on VCR. The buttons are small enough that I've often found it easier to use two hands. (Interestingly, using an MRC with a Canon camera, I can work with the camera's record button whether or not there is tpe in the carriage.) I tried researching the LancC connections but never found out how it works with the FX1000/Z5 cams and a Ninja. The Ninja's manual --- at least when I looked at it --- basically said nothing more than that there was LanC connectivity and it allowed for "remote" operation. (Maybe this means you can run the Ninja from a tripod controller?) (b) In terms of portability and blance, the MRC unit has it hands down over the Ninja with a Z5. Tthe MRC simply snaps into the back of the Z5 and runs off the same battery. A lot less extra weight and no balance problems for handheld shooting. WIth a Z5 on a tripod, its pretty easy to start and stop recording even without tape in camera. (c) Cost -- you have to figure in both device and media. The MRC goes for $750 (US$) and 32 gb CF cards run about $60 to $70. A 32 gB card will be good for about 180 minutes of recording HDV from a Z5. You'll want a couple of cards (for when you do not have time to download and back-up the card contents and for longer shoots. So, to start with, figure about $900 to go with an MRC. The Ninja is $995. The ProRes recording format requires a lot more space than straight HDV. It needs about 100 gB/hr. for the highest quality ProRes recording. (In other words, ProRes files will use roughly 7½ times the space of ordinary HDV.) To get 3 hour recording capacity, you would need some 300-340gB laptop drives. Last time I checked, 2.5" drives with 300-340 gB capacity seemed to be going for between $80 and $120 depending on the maker and whether you want 7200 rpm speed. (Atmos says that the Ninja works fine with 5400 rpm dirves, by the way.) You would want to buy two drives for the same reasons you would want at least two CF cards with an MRC. So, a comparable cost on a Ninja with 6 hours of recording capacity would be roughly $200 to $250 more than an MRC. Having the ProRes HQ footage might be worth an extra $200 to you. It might not. The economics look a lot different if you need to run in higher vibration environments, like the concert shooting that Gerald mentioned, More on this in a moment, but the cost of an SSD is about 4 to five times the cost of a mechanical 2½" drive. I looked at SSD's a couple of weeks ago when I had to hurriedly build a new editing workstation. The prices for 300gB SSD were well north of $500. (They may come down in the future when the Asian factories recover from the Thai and Japanese disasters, but that seems to be a long time coming.) So, equipping a Ninja with SSD capacity can be considerably more expensive even if you got one mechanical drive and one SSD. Still less than half the cost of buying a comparable camera to replace a Z5, though. (c) Durability and vulnerability: not a good idea to drop anything with an lcd screen. That said, one of my MRC units fell off a top shelf onto my editing desk and it still works fine. If this had happened while recording, I'm "guessing" I would have lost some video. But maybe not, One of my MRc-equipped fixed cams was knocked over at a dance rectal last spring and I lost no video. The Ninja is bigger and heavier than an MRC and thus more susceptible to damage from falls. As you would expect, the Ninja manual has specific cautions about this. (d) Disk shock and vibration resistance/hard drive stoppage (Gerald's question about extremely loud concert environments). Maybe Jeff can speak more to these variables since he has actually used the Ninja for concert shoots. Without his direct experience, I offer my 2 pennies worth. As I recall, the manual for the Ninja specifically said to use SSDs in high vibration environments. Atomos was not specific about this means. How much vibration and noise is "too much" for a mechanical harddrive? One thing that occurs to me is that, if you are shooting the kinds of projects where you need to use ProRes rather than HDV, you probably have the kind of budget that will cover at least one SSD. Otherwise, I'd say that CF cards with an MRC would be a much more budget friendly way to upgrade and prolong the useful life of a Z5 where you may be shooting in stressful environments. This should not be taken as an offhand comment. I can say that I've never had noise and vibration cause an MRC to shut down or fail with an FX1000 even when there was so much noise and vibration that that the shaking made the footage unusable. I've also done some similar shoots in the past while feeding a camera via On-Location to a laptop computer, all perched on the top level of very springy bleacher seating. As long as I hand-held the camera (and had image stablization enabled), I had no problem with recording to the lapop. Whether this was a bad an environment as Gerlad ran into, I cannot say. What I can say is that that my laptop's mounting for the drive was likely much better than the mountings for the internal hard-drives on consumer handycams. Also, some 2.5" laptop drives are more vibration resistant than others. Plus, you may get gyroscopic effects when hand-holding a camera with a mecahnical hard drive, and those effects can contribute to problems . The Ninja mounting set-up may be more vibration resistant than, say, what you would find with the a hard-drive mounting in a consumer handycam. (Although the Ninja manual did mention the possibility of gyroscopic effects when the Ninja is mounted on a camera.) These variables make it hard to generalize about when you can get by with a Ninja using mechnical drives and when you must have an SSD. Gerald's example of the hard-drive camera --- which I'm assuming was a small consumer cam --- may not translate directly to running a Z5 with a Nina. The Z5/ninja combo wil have several times the mass of a handycam and will likely be sitting on a reasonbly sturdy tripod which may counteract the kinds of difficulties that make a small handycam's drive fail to record. I can say I've never had any trouble with starts/stops when using my NX5 (which is essentially a Z5 with a 128 gB SSD) nor any trouble with starts and stops with the MRC units I use. I've only worked once with a hard-drive equiped consumer handycam and it seemed very vulnerable to vibrations. These points, I think, bring us back to Adam's earlier points. It seems to me that, unless you truly need/want the benefits of ProRes recording and are regularly shooting in stressful environments , the economics favor getting an MRC. . If you will be shooting in less stressful situations and need or want the ProRes frmat, a Ninja with a mechanical hard drive may well be worth the extra couple hundred dollars. |
Jay, thanks again for that in-depth reply - I really appreciate the volume of information in that post. It answers my question perfectly. I already run the MRC from a Z5 and am extremely happy with the quality, ease of use and positioning on the camera. For me pro-res is not necessary as most of my footage ends up on the web, not broadcast, although some is played on large display LCD's for corporate promotions.
Since most Sonys have a very similar button and menu set-up I occassionally hire an XDcam for broadcast needs and charge accordingly - this could be a better option than a Ninja for me. Cheers mate. |
Jay, thank you so much for all that info :)
Food for thought on so many levels. Im leaning towards the MRC now, fact is, when comparing footage from my Z5 to my hacked GH2, the Z5 stands up pretty well even though it is only HDV. Good enough for multi cam shoots anyway. Now I just need to find a back heavy shoulder mount. Is it just me or is the Z5 extremely front heavy and awkward to hold for long periods? Anyone suggest a good shoulder mount? |
+1 jay. excellent summation (again!)
and i agree entirely with chris - if i need anything better then i'll hire it. however, considering the quality i'm getting from the z5, and having shot with other cameras i really can't see the need, other than perhaps for heavy-duty chroma-keying for broadcast, and even then, with a proper setup, i doubt i'd bother. |
Let me add another thought to my essay. This is why I would think about getting a Ninja rather than an MRC.
I mainly shoot from tripods, so the size and positioning of of the Ninja would not be a problem for me. I do a lot of multi-cam shoots. When I have the time, I often convert my HDV and AVCHD footage to Cineform AVI. This allows for easier color matching and, when running a seven track multi-cam edit in PPro, the conversions make for a lighter load on the system. (I have an array of disks and RAIDS so the requisite disk space is not a limitation for me.) Using Ninjas and ProRes would save some of the transcoding time and make camera matching easier. So, If I did not already have MRC units, that is why I would be looking at the Ninjas rather than the MRC units. |
Just to revisit the Ninja/MRC debate again. I recently have been ingesting my MRC m2T files with an editor into FCP and the amount of time they take to transcode into Pro-res via mediastream is extraordinarily long - does anyone else get this?
Mediastream seems to transcode each file and make it 5 times bigger when it's turned into pro-res? My editor mate recently transcoded about 50 files in a batch and it came out as one big 140gb file that was unreadable? Anyway, I digress...for pro-res editing in FCP Ninja may be the way to go perhaps? However I use PPRO5.5 so not sure I want to go there at all. Anyone heard about the recent NInja 2 release? |
| All times are GMT -6. The time now is 02:41 PM. |
