Flange Back focus for Z7U on other lenses at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old July 15th, 2008, 10:31 PM   #1
It seems that the flange focus on the Z7 only works while my carl zeiss lens is connected. Once I disconnect that lens and use a 1/3" to 2/3" adapter with a fujinon 2/3" lens, then the flange focus menu option is greyed out. I also would like to set flange focus for some of the nikon lenses I am using, which I have adapters for to fit onto the Z7.. Is this possible? The manual seems to say that flange focus only works with a carl zeiss lens? Is this correct?
Max Carlson is offline   Reply With Quote
Old July 15th, 2008, 11:32 PM   #2
Max:
I am looking at this camera, for use with my Nikon lenses. I don't know the answer to your question, but I am curious if your able to focus to infinity using the Nikons with your adapter. I understand it may focus through it, but will it at least get to infinity.
Chris J. Barcellos
Old July 16th, 2008, 07:07 AM   #3
You would use the backfocus adjustment on any 2/3" lens attached to the adapter.
I doubt there is any backfocus solution for Nikon lenses on the Nikon adapter. However I would assume that the long focal lengths used would make it easy to front focus any shot by eye.... just don't zoom within the shot.
Tim Dashwood
Old July 16th, 2008, 10:10 AM   #4
The latest generation of lenses uses Lens Files to convey correction parameters for the lens to the camera. The camera talks to the lens continuously even when the unit is in full manual mode for the purpose of optimizing the image. The Lens files can be loaded manually on some cameras, but are usually loaded from memory contained in the lens. The backfocus adjustment in the Z7 and EX series only updates the lookup table (LUT) that is used to drive backfocus lens corrections.
For (mechanical) lenses that cannot be corrected by the camera, the FB Adjust is unavailable. You need to mechanically adjust backfocus, just like on other pro lenses/camera's.
For SLR-type lenses there usually is no way to adjust the backfocus unless the adapter provides this functionality.
George/
P.S. For the Z7 see page 10 of the manual (bottom right): it can only read lens files from compatible lenses and store up to 10 profiles.
Last edited by George Kroonder; July 16th, 2008 at 11:56 AM. Reason: Added the P.S.
George Kroonder is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
