remove mic holder at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old July 14th, 2010, 08:09 AM   #1
remove mic holder
if at all possible how do I do that on the AX2K ? it is so exposed so when traveling I guess it would be wise to remove it.
Giovanni Pietro is offline   Reply With Quote
Old July 15th, 2010, 11:23 AM   #2
I agree. I can see the screws but haven't tried it yet. Seem easy to strip.
Marc Myers is offline   Reply With Quote
Old July 20th, 2010, 11:57 AM   #3
I have removed the mic holder and reinstalled it without any issues, just use the correct size screw driver so you don't strip the screws.
Ben
Ben Moore is offline   Reply With Quote
Old July 23rd, 2010, 07:03 AM   #4
How do you get to the screws? I just can't find them....
Nick Popa is offline   Reply With Quote
Old July 27th, 2010, 04:57 PM   #5
Yeah, where are the screws? I can't find them either.
Junior Pascual is offline   Reply With Quote
Old July 28th, 2010, 09:06 AM   #6
Open up the clasp, remove the microphone and look down into the assembly where you'd expect screw to be attached. they are down there just a little hard to see.
Old July 29th, 2010, 06:31 AM   #7
Could someone with an NX5U and one of these < EX1, EX1R, or EX3> confirm that the microphone holder screws are equally spaced and the same size/type??
Reason being, I wanted to buy the J-Rod twin-mic adapter.
http://www.bhphotovideo.com/c/product/685140-REG/J_Rod_SUPER_STRONG_TWIN_MOUNT.html
Old July 29th, 2010, 11:24 AM   #8
Thanks, Marc. I previously looked in that area and could not see them. Didn't realize it was so deep & dark in there!
Old July 30th, 2010, 05:57 PM   #9
I compared the microphone clamps on my EX1 (not R) to my NX5 and:
1) The hole spacing is NOT the same.
2) The EX1 surface is planar with the bottom of the camera. The NX5 is sloped down at 15-20 degrees.
3) The microphone clips are not the same, even without the hole spacing difference. The EX is more substantial and uses a thumb-screw closure, while the NX is a bit lighter-weight and uses a wire hasp.
4) The screws in the EX are easily removed. I was unable to remove the screws in the NX because I could not turn them and didn't want to risk stripping the heads for the sake of this experiment.
Richard Crowley is offline   Reply With Quote
Old July 31st, 2010, 08:20 PM   #10
Thanks so much for comparing them for me. Saved me $30
Old August 16th, 2010, 01:44 PM   #11
I was unwilling remove the microphone holder for fear I'd strip the screw heads. Today I took my camera to Sony in New Jersey along with four EX1's I needed to have flashed. They took the mic holder off with a smile. Seated the screws back in the base to make sure they didn't disappear.
Thanks Sony!
