HDMI Monitor not displaying cam info at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old January 22nd, 2011, 10:34 AM   #1
Hey,
I just purchased the Marshall M-LCD7-HDMI-B-CE6 monitor kit, and when I try to use it with the Nx5u, it will not display the info on the monitor when using the hdmi cable. It does show what the lens is seeing, the timecode, and does show the menu when I press the menu button, but it does not show the aperture, audio, battery, etc...
Even if I use the rca cable (red/yellow/white) I do not get the display info,
Before you tell me to check settings, here is what I have checked, checked, and rechecked:
1. Menu> Display set> Display output> all output
2. Rec/out set> video out> Output Select> HDMI
3. Rec/out set> video out> Sdi/hdmi/component> 1080i/480i
4. Rec/out set> video out> down convert type> Letter box (16:9)
Nick Popa
Nick Popa is offline   Reply With Quote
Old January 24th, 2011, 12:20 PM   #2
Have the same issue with the AX2000 with that same monitor, or my Dell 23" external monitor ....
David Wayne Groves is offline   Reply With Quote
Old January 24th, 2011, 12:41 PM   #3
Look under the "DISPLAY SET" menu. Set "DISPLAY OUTPUT" to "ALL OUTPUT".
Vic Wilcox, http://wilcoxvideoproductions.com/Default.aspx
Sony HXR-NX800, DJI Phantom 4 Pro, DaVinci Resolve Studio 19
Victor Wilcox is offline   Reply With Quote
Old January 24th, 2011, 12:51 PM   #4
Make sure MARKER is off. Page 77.
Old January 24th, 2011, 05:17 PM   #5
Thanks so much Adam, I didn't realize that would be an issue, I find that very strange that you can't use the marker and the monitor. But something's better then nothing!
Old January 24th, 2011, 05:43 PM   #6
Yeah, you're not the only one who's gotten tripped up by this little quirk...
Old January 24th, 2011, 06:23 PM   #7
another trick I learned is to put the nx5u on "expanded focus." Only the camera's LCD or viewinder actually expand but the external monitor will display all the info
Old January 24th, 2011, 06:58 PM   #8
Now working with the AX2000 as well, as stated turning markers off fixed the problem...Thanks...
