4:2:2 out of HD-SDI port? at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old June 3rd, 2011, 08:38 PM   #1
Hi everybody,
I was reading up some where a while back but cant seem to find the article.. i read that this camera doesn't out put true 4:2:2 out of the HD-SDI port? i could be wrong but thought i would double check. another question i have is that, If i had an external recorder that took HD-SDI would the picture quality be higher then me shooting at 24mb/s onto Pro Duo cards? This may be a rhetorical question but im still learning lol
Mike
Mike Butir is offline   Reply With Quote
Old June 3rd, 2011, 10:08 PM   #2
Re: 4:2:2 out of HD-SDI port?
All my research says it does output 4:2:2 10-bit. However, the 10-bit data steam has 0 in the top 2 bits yielding 8-bit data.
Vic Wilcox, http://wilcoxvideoproductions.com/Default.aspx
Sony HXR-NX800, DJI Phantom 4 Pro, DaVinci Resolve Studio 19
Victor Wilcox is offline   Reply With Quote
Old June 3rd, 2011, 10:47 PM   #3
What about the HDMI port? does that output the same uncompressed HD as the HD-SDI port as well?
Old June 4th, 2011, 09:21 AM   #4
The specs are the same.
The 8 vs 10-bit data information (Quoting from memory here.) came from Douglas Spotted Eagle. I believe he got the information from a Sony rep.
Old June 4th, 2011, 11:50 PM   #5
so if i bought a Ninja, i would be recording higher quality to that then the Pro Duo cards in my camera?
Old June 5th, 2011, 06:30 AM   #6
That would be a "YES". Just wish a Ninja was in my budget.
Old June 5th, 2011, 04:44 PM   #7
kind of a rhetorical question again.. but would it be significantly better quality? what would i notice between shooting to the ninja vs pro duo cards?
Old June 6th, 2011, 01:24 AM   #8
You can easily check it out for yourself. Just record a scene and play it back on a good TV/ monitor, then aim the camera at the same scene whilst viewing the image live on the same monitor via the HDMI. You would of course need to choose a scene that could be reached whilst the camera was connected to the monitor.
In effect, the HQ recording mode of the Ninja (Pro-Res HQ) is virtually indistinguishable from uncompressed HDMI output, - certainly with a middle of the road pro-sumer camera like the NX5.
Steve
Steve Game is offline   Reply With Quote
Old June 6th, 2011, 05:49 PM   #9
Yes i can Confirm that the HDMI & HD-SDI Port are at a Higher Video Picture Qulty, as it bepass's the internal codec and chip. So if you use these ports and use something like a ninja or other external recordering device you will be able to record at 4.2.2 and at a higher bitrate.
Dipesh Parmar is offline   Reply
