Gain IOS scroll controll
Is there a way to scroll through different DB's or iso's instead of only having the H/M/L setting with out going into the camera and changing the default H/M/L settings?
Re: Gain IOS scroll controll
Short answer no. That's a DSLR thing. The 700 was designed around the commonly accepted practice on video cameras of having L/M/H gain settings. A shame I know.
There is a sort of semi-workaround I have found useful on a number of occasions. Usually if you want to work at a set aperture on a manual lens although it will work with any lens basically if you want to lock the iris at a given aperture. First set a top limit on your 'Auto ISO Limit' setting. Let's for argument in this example say 4000 ISO. Now assign 'AE Shift' to one of your assignment buttons and set the 'Gain/ISO' switch on the left to 'Auto.' If you are working with an E-mount lens it will have to be in manual focus mode for the following procedure to work. You can still use the momentary ‘auto-focus’ button but in doing so it will de-activate the AE Shift button so you will have to tap that AE shift button once more to access the AE Shift adjustability. Ok what to do now? What this set-up will allow you to do, let's say working with the 18-105 locked at F4, is that you can now roll the left side menu roller wheel between 800 and 4000 ISO once you have activated the assigned AE Shift button. The AE Shift function has a range of +/- 2.0 stops. Keep in mind that the ISO is still in 'auto' mode so the auto ISO will still react to reasonable changes in light levels. In fairly stable but still changing light conditions it now gives you the ability to adjust your exposure fairly smoothly over a 4 stop range whilst maintaining a constant aperture. Yes it’s a fudge but it is useful workaround in some situations. I find it works best working with my manual primes and zooms. You may have some luck with ‘the fudge.’ Chris Young CYV Productions Sydney |
Hi Chris
I use the very same on my EA-50! However I'm only using manual lenses so I can actually leave the camera in auto (just for ball park exposure) and then set my ISO (I use gain still but it's the same thing) to a max level (21db for me) I then have assigned AE-shift to a custom button and if I'm not happy with the camera's exposure (say in a backlit situation) I can blip the AE shift button and adjust up or down. Dunno if the 700 is the same but it will only adjust AE shift if the icon on the EVF has a highlighted rectangle on it so sometimes I have to give the button a second tap to make the AE shift "active" It works very well and gives you ISO adjustment in nice small steps too without needing to physically adjust the aperture which might mess up your DOF Good tip and I assume it will work the same on the FS100 as well? Chris |
#4 | |
#5 | |
All best in the west for '15 :) Chris Young CYV Productions Sydney |
#6 |
Thanks Chris
Hope you also have a great 2015 over East!! Chris |
#7 | |
That h/m/l setting is something all professional camera have but only really worked on smaller sensor camera's that got too noisy once you went past 6b like on my xh-a1 so you just assigned 0, 3 and 6 db gain which worked perfectly for any situation. But with today's large sensor and low light sensitive camera you want to be able to cover a range between the lowest and highest iso because almost all are usable and then such a switch can be a real pain. As I see it it's a design mistake Sony made. |
#8 |
"As I see it it's a design mistake Sony made."
Yes in this day and age where nearly everything is programmed into FPGAs you would think that it wouldn't be too hard to implement 'Dial an ISO' unless there just isn't the hardware links to do it. That is one aspect that's quite nice on the X70 is that you can dial gain from -3 to +33dB in 3dB steps very quickly and fairly smoothly on the roller wheel. Chris Young CYV Productions Sydney |
#9 |
To be perfectly honest, I don't have any issue at weddings using the EV Shift. As long as my gain is limited to 21db on the EA-50, 99% of all exposures fall within the auto exposure range so I only really need to tweak if I have a severe backlit situation which I obviously try to avoid and in situations at dark wedding venues where I have the speech makers lit against very dark walls so I use EV shift to again avoid the skintones being blown out when the camera "sees" lots of black and only a tiny portion of well lit subject. I remember my old Panasonics had to be locked out at 9db otherwise I got a lot of noise so a H/M/L switch at 3, 6 and 9 was quite practical but with the bigger sensors you simply have too much gap between min and max ISO
However, yes a scroll wheel would be nice but the EV value is not a hard workaround to implement once you get used to it and I cannot see Sony changing firmware now anyway. At least there IS a workaround which is practical. |
#10 | |
