#31 |
Contributor
> Buy a pdx10 PAL, get 20 pct more resolution,
> shoot as clean as you can and then play with the > picture in post. Should look very nice. Yes, should look nice. I actually thought about doing this, using a tool which I think is called DVFilm Atlantis. It's a great idea if you have the time for all that processing. And if you are transferring to film it should make even more sense. But I do some TV work so the prospect of processing everything just was not too attractive... also: in my market it costs more to get hands on PAL equipment.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands. |
#32 |
I am thinking that applying a little motion blur will help achieve the film look for this reason. If you think about it there is persistance beyond the 1/60 or even 1/30 (1/24) for film that allows some after image to remain with the eye causing a slight overlap, in the mind anyway, of the preceeding and next images. A slight motion blur might help simulate this effect that would be naturally happening in your mind in a theater.
Just a thought. Sean
‘I don’t know what I’m doing, and I’m shooting on D.V.’ - my hero - David Lynch http://www.DeepBlueEdit.com |
#33 |
On the Mac, Joe's Filters provides a nice plug-in for this. I found it useful for making computer animation look a bit more like real footage. Certainly worth experimenting with, but a good deinterlacer will probably do what you want. Joe's Filters also has that, or another option is DVFilm Maker.
#34 |
RED Problem Solver
Boyd, have you tested the new DV Film Maker yet that does 24p? I tried it but got very bad flicker that made it unusable.
Graeme
www.nattress.com - filters for FCP |
#35 |
Contributor
Motion Blur and more
Yes. Motion Blur is the way to go. In FCP I can control the strength and the amount of samples for motion blur. The more samples, the more render time, the smoother it looks.
If I add to this some non-linear transfer function (like Stib's Film Curves) then I get a really very 'film like' result. Well actually what I see is similar to that of film transferred to video. Applying 'film' curves helps get more contrast from the mids, this especially helps if I underexpose a bit, wich also keeps the highlights from being slammed video style. I also like to do other non-linear stuff like desaturating highlights and lowlights, you can do this with one of Apple's plugs. It is also possible to use Stib's curves to seperately affect color channels, adding a non-linear tint to the picture. This makes for a really nice effect as seen on many music videos. Of course, any blurring will --well-- blur the picture a little bit. This might seem like a resolution loss sometimes, but it has the added advantage of reducing noise and chroma artifacts, which is something good if using Stib's Film Curves or something like that with DV-originated material. So as you see it all kind of fits together, 'film' curves, motion blur, underexposure. Stib's free plugs: http://www.scriptgeek.netfirms.com/ Graeme's plugs: http://www.nattress.com/ Too Much Too Soon: http://dtlx.datom.se/~mas/index2.html CHV Silk & Fog: http://www.chv-plugins.com/silkandfog_m1.html More (the original link): http://www.digitalzoo.com.au/lunchti...ed_02_free.htm I would love to post some footage but I can't right now because of bandwidth and space limitations. Sorry for the long post. Hope it helps.
#36 |
Could you repost that link? The "..." are confusing my browser as the link was shortened somehow.
Thanks, Sean
#37 |
Contributor
Ok, sorry for the inconvenience. Added some direct links and fixed the original one.
