TRV900 -- various questions - Page 5 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old February 3rd, 2005, 06:59 AM   #61
Why go from TRV900 to XL2?
Being somewhat of an amateur after reading these posts,what would I,or anyone else for that matter,gain from going from the Sony TRV900/950 to the Canon XL2 ?
Would we see an immediate increae in quality/resolution/colour etc.
I have had good results with the TRV900 being a 3 CCD cam and am interested in a more expert view.
Steve Puttock is offline   Reply With Quote
Old February 3rd, 2005, 07:15 AM   #62
The differences are so profound I don't know where to begin... off the top of my head these are some of the advantages:
1. interchangeable lenses, including fully manual if desired (although $$$)
2. option for BW CRT high resolution viewfinder (also $$$)
3. True progressive scan CCD's with 24p and 30p modes. This permits you to shoot at the full 480 lines of vertical resolution instead of ~360 lines used for interlaced cameras like the 900.
4. 1/3" CCD's vs 1/4" on the 900 or 1/4.7" on the 950. Means better low light response, less vertical smear.
5. Far more options for picture control in terms of parameters which can be tweaked via menus.
6. High resolution 16:9 mode. Big difference from the cropped 16:9 on the 900.
I'm sure there are others, but these cameras are just in completely different leagues. Of course you would expect this from a design that is several years newer and a price that's at least 3x more than a 950 for the base model. There would be disadvantages as well though, it's bigger and heavier for one thing.
Old February 3rd, 2005, 09:53 PM   #63
Boyd,thanks for the informative reply.
Guess I should start saving....
Old February 7th, 2005, 11:04 AM   #64
TRV900 lens hood
Does anybody know if the Lens hood on the TRV900 is available for sale anywhere?
I have a lead on a TRV900 that does not have the lens hood.
Is the lens hood functional at all? Will I miss not having it?
Toogood Studios
Jeff Toogood is offline   Reply With Quote
Old February 7th, 2005, 01:49 PM   #65
Searching for parts/acessories on Sony's consumer site only turned up things like batteries, straps, etc. However if you go to their professional site and search for pd100 then follow the appropriate links you eventually get to 51 pages of parts! I don't know much about the TRV-900 or PD-100, so maybe it's not a valid assumption that the lens hoods are interchangeable? Perhaps someone else can help with that.
Anyway, here's a link to Sony's "PartsPLUS" website. Unfortunately you can't link to individual pages within the site it seems: https://servicesplus.us.sony.biz/PartsPlus.aspx
Old February 9th, 2005, 06:10 AM   #66
Depends where you live Jeff, but Sony parts are readily available in the UK.
The TRV900's hood is a beautifully made and rather expensive piece of kit consisting of 8 parts. It bayonets onto the lens but in so doing means you can't fit filters to the lens - they have to fit inside the hood itself. Of course this is very bad practice as the filters are a good 10 mm from the front element, and any dust etc is much more likely to be (auto) focused on. Not only that, but by fitting filters inside the hood you decrease the efficiency of the hood tremendously - you've effectively moved the front element forward by 10 mm but kept the hood in the same place.
If I were you I'd not bother with the official 900 hood - I'd go out and buy a Hoya collapsible hood in a 52 mm fitting. Much more efficient (especially if you're doing a lot of telephoto work), much cheaper and you can fit filters right up against the zoom lens.
tom.
Old February 9th, 2005, 07:28 AM   #67
Is this the lens hood you are talking about?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Toogood Studios
Old February 9th, 2005, 09:12 AM   #68
That certainly looks like the one - matt black rubber with a fine red line round the circumference at the front. The hood can be pulled / pushed into three positions but beware - the 900 (along with very nearly all camcorders) masks the side-screen and the v'finder, so you might not be told of full frame cut-off till you see the full frame image on your pc. Time for a test or two.
But it's a great hood and if you're doing a lot of telephoto work on safari for instance, the hooding can be very efficient indeed - much better than the stock hood which is only efficient at the wide-angle end of the zoom of course.
tom.
Old February 11th, 2005, 09:25 AM   #69
Wide Angle lens for TRV900?
Did a search and didn't come up with much. What wide anlge converter lens are out there for the TRV900?
It has a 52mm thread size.
Toogood Studios
Old February 11th, 2005, 08:49 PM   #70
Check out the canon wd58
John Hartney
Elgin, Illinois USA
847.742.9321
John Hartney is offline   Reply With Quote
Old February 12th, 2005, 11:03 AM   #71
The 52 mm attachment thread size is very well catered for out there in wide-angle land Jeff. Sony make some, as do Tecpro, Raynox, Kenko, Century, Cavision and others.
What you really need to decide is if you want a full zoom-through and what power you want. The less powerful 0.7x converters seem to suit a lot of folk, but I for one want a good and powerful 0.5x if I've gone to all the hassle of fitting it.
If you do get a w/angle, do get a lens hood for it too. It's even more important to hood the lens because you've added more glass elements in front of your camera's zoom, and more elements = more flare.
tom.
Old February 14th, 2005, 08:15 AM   #72
I am looking for a full zoom through lens.
I know there is lots of 52mm lens out there. I guess I was asking for some personal experiences with any of them.
I had a Canon WD-58H on my old GL2, and I imagine that would be huge on a TRV900, would it not?
Toogood Studios
Old February 14th, 2005, 08:45 AM   #73
No, the Canon lens should be just fine on the Sony. You'll need a step-down ring (58 >52). You still have the lens? Give it a go.
tom.
Old February 15th, 2005, 06:45 AM   #74
I purchased a Wide Angle lens for my TRV900 ,a Vitacom 0.45X Semi Fisheye Pro AF and its OK except for vignetting at maximum wide,so best check it on the cam before purchase
Old February 15th, 2005, 08:13 AM   #75
Better yet - check it on the computer monitor, The cam's side-screen and v'finder mask off quite an appreciable chunk of the captured image.
topm.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
