DVCAM footage playback? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old November 4th, 2005, 09:15 PM   #1
Will a sony single chip miniDV camera playback the DVCAM tapes or will I need to use a DVCAM camera?
ScapeFilms.com | My Photography | IMDB Profile
Mike Tesh is offline   Reply With Quote
Old November 6th, 2005, 03:53 PM   #2
a cut and paste from:
http://www.sony.ca/dvcam/support.htm
3.(Q) Are consumer DV and DVCAM compatible?
(A) Both consumer DV and DVCAM are closely related, so much so that all DVCAM equipment also carries the DV logo guaranteeing full DV playback compatibility. As well most Sony DV products, except for the original two camera's (DCR-VX700 and VX1000), also have full playback compatibility with DVCAM tapes. Many other manufactures DV products can playback DVCAM as well. In essence the record footprint is the largest difference between the two formats (DV=10um, DVCAM=15um) The DVCAM format is really just a professional extension of the DV format designed to meet the rigors of professional use. In fact one way to consider DVCAM is that it is the standard play mode providing superior professional performance and DV is the longer play mode of the format which provides performance consistent with consumer use.
so there's no certainty that one particular camera will allow playback, I think it's a case of try it and see
Matt Brabender is offline   Reply With Quote
Old November 6th, 2005, 07:47 PM   #3
Excellent, thank you for the information.
Old November 19th, 2005, 07:07 PM   #4
I've found that my TRV10 and TRV8 can play back DVCAM tapes recorded in my PDX10 and Z1.
Ed
Ed Griffin is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
