PD150 "Clock Set" & other continually at DVinfo.net
Old February 25th, 2008, 02:11 PM   #1
Something just to my menu settings on my PD150. Every time I take the battery off, I'm having to reset several settings in my menu including Clock Set, Rec Mode, Audio Mode, Mic NR, Rec Lamp, to name a few.
The only thing I did recently was try a new memory stick (Magic Gate), which didn't work.
Is there an internal battery that needs changing?
Chuck Volm is offline   Reply With Quote
Old February 25th, 2008, 02:18 PM   #2
Yes, it is buried under one of the panels. There is a set of instructions somewhere, either on this forum (do a search here) or on the Internet (use Google).
Mike Rehmus
Old February 25th, 2008, 03:09 PM   #3
Thanks a ton!
Old February 25th, 2008, 03:27 PM   #4
About the internal battery PD150
I found the answer on page 157 of the Sony PD150 manual.
