Dvcam at DVinfo.net
Old April 17th, 2004, 12:37 PM   #1
Dvcam
Can someone explain the DVCAM recording standard? If I shoot in this standard, can I play back the tapes on plain old DV decks? I have an old TRV900 that I would like to use as my logging and capturing "deck" for a doc I'm shooting. Can I do that if I shoot on the PD170 in the DVCAM mode? And can I import it into Final Cut Pro using the DV preset?
David Lewis is offline   Reply With Quote
Old April 17th, 2004, 03:16 PM   #2
Outer Circle
Hi David! Take a look at this site:
http://www.adamwilt.com
Old April 19th, 2004, 06:46 PM   #3
great site frank, thanks! tells me a lot...which kind of makes me think it's a crap shoot. what I don't understand is if the tape moves faster in dvcam, how can it be played back on a regular dv "deck"?
Old April 19th, 2004, 08:18 PM   #4
It cannot necessarily be played back on a DV deck unless the deck is a Sony (which are all DVCam decks) or one of the selected professional JVC and Panasonic decks.
Many but not all Sony cameras can play back DVCam recordings. I do not believe any other camera brands can do so.
Mike Rehmus
Old April 21st, 2004, 08:36 AM   #5
The Sony tape decks measure the frame pulses written to tape Dave, and physically change the speed of the capstan drive when you switch from LP to SP to DVCAM. You can actually hear the DSR11 change speed as different recordings come its way. The heads continue to spin at the same speed of course, as the 9.5m/sec writing speed is unchanged between the LP, SP and CAM speeds.
tom.
