Autoshutter option in Manual Set Menu(VX-2100) at DVinfo.net
Old August 15th, 2004, 01:18 PM   #1
When Autoshutter feature is on, does it only apply to when you leave the camera in auto mode?(not set the shutter and aperature manually)
Or will it be on if you set your exposure manually?
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old August 15th, 2004, 01:52 PM   #2
The Autoshtr feature is only active in full auto.
Andre De Clercq is offline   Reply With Quote
Old August 15th, 2004, 06:28 PM   #3
<<<-- Originally posted by Andre De Clercq : The Autoshtr feature is only active in full auto. -->>>So if you turn it off while in auto mode, does it keep the shutter at 60?
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Old August 16th, 2004, 01:15 AM   #4
Best to turn it off in the menu and leave it off. I cannot think when you'd want to use it, but it's really there as a long stop, for those who shoot on auto exposure and ignore both silent screams for the NDs to be inserted. If this happens and the camera's shooting at f11 the camera will then up the shutter speed to correct the exposure (but won't reduce it funnily enough).
tom.
Old August 16th, 2004, 03:21 AM   #5
Yes Ray when autoshtr is turned off you will stay at 1/60 and aperture will go up (beyond f11) if the incoming light gets too high. Diffraction effects reduce resolution in the latter case.
