Sony announces new 4K camera systems PMW-F55 and PMW-5 - Page 3 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old November 1st, 2012, 11:22 AM   #31
Re: Sony announces new 4K camera systems PMW-F55 and PMW-5
I hope so too Paul.
We were going to get a pair of Scarlet packages for an upcoming project after we realized there was not going to be any 60p on the C300s (our first choice.)
We've put all decisions on hold until we get the full info on the F5s.
Jim Giberti is offline   Reply With Quote
Old November 1st, 2012, 11:43 AM   #32
I was also looking at getting a Scarlet this month but put that on hold. The C300 was purchased the end of Sept and has worked hard and will work hard till the second camera shows up. I think the C300 now that I own it will be a nice B-Cam for the Scarlet or F5. Does not look like the C500 is even in my sights anymore.
I do find the C300 image quality matches or exceeds the PMW500, F800, 700 range of XDCAM, in a much smaller package and loads of lens choices for a fraction of the cost.
Paul Cronin
www.paulcroninstudios.com
Old November 1st, 2012, 08:47 PM   #33
Sony are incredible. It seems hardly a month goes by without a major new release. Meanwhile i've heard nothing from Panasonic for what seems like aeons. No doubt they'll be back with new gear at some point, but in the Sonycentric UK at least, it's hard to see how they'll pick up much of the market share.
Dom Stevenson is offline   Reply With Quote
Old November 2nd, 2012, 03:49 PM   #34
You are not restricted to Sonys EVF options, you can use third party EVF's like the new Cineroid or Alphatron,. I think Sony realise that for the F5 in particular to really be a hit the package price is crucial hence the small 720p EVF.
Old November 2nd, 2012, 05:43 PM   #35
Originally Posted by Paul Cronin View Post
Jim have you ever purchased a VF for a PDW F800, 700, or PMW 500? I had a C35W with my XDCAM Line. The C35W is $11K retail and that is not up to what they will offer with these cameras. So yes $10K is what I think the VF will cost.
Happy to be proven wrong but these are not budget cameras.
If you can go out and buy an ipod touch with a retina display for $299- why would you need to spend 10K on a viewfinder?
If you can get a display that good that cheaply, what's the other $9700- going to be spent on?
http://www.markoconnell.org
Mark OConnell is offline   Reply With Quote
Old November 2nd, 2012, 07:34 PM   #36
"The next big thing is already here."
I'm sure the ipod touch retina is a great display for $299, but quite honestly, if you don't understand the value of having an optical viewfinder attached on your F5 or F55, you should probably go ahead and just record the video with the ipod as well.
Old November 2nd, 2012, 10:11 PM   #37
Hard to find any faults with that F5 camera.
About the high speed feature, Juan Martinez of Sony had this to say;
"And even at high speed, there’s no limit to the recording time because the cameras are not recording to a buffer and then spooling off to the recorder. You can record high frame rate for as long as there’s room on the card or in the recorder..."
And it can take Canon lenses.
TVTechnology: New Sony Cameras Designed for 4K TV
Old November 3rd, 2012, 02:31 AM   #38
Mitch Gross points out the differences between the Colour Filter Array of the sensors used on the F5 ans F55.
Sony’s PMW-F5 and F55: Defining CFA | CineTechnica
Old November 3rd, 2012, 08:06 AM   #39
Great article, Brian. Thanks for pointing it out. I particularly liked the explanation as to why the F5 sensor is rated at 2000 ISO and the F55 at 1250 ISO.
David Knaggs is offline   Reply With Quote
Old November 3rd, 2012, 10:58 AM   #40
Agree David a must read by Mitch Gross to learn about the two sensors.
Paul Cronin
Old November 3rd, 2012, 11:25 AM   #41
I wasn't suggesting that you don't need an EVF, but making the point that the components that go into one are not going to cost 10K.
Old November 3rd, 2012, 11:43 AM   #42
optical??!
Charles Papert
www.charlespapert.com
Old November 3rd, 2012, 01:33 PM   #43
Yes, I agree.
Old November 4th, 2012, 10:11 AM   #44
Originally Posted by Jim Giberti View Post
The F5 will compete with the Scarlet and the C300 pricing. That's the new benchmark for an affordable, professional film making rig. And Sony knows that they can own that market because the F5 offers so much more than the C300.
I think this might compete more with the C500. In addition to purchasing a viewfinder, almost all of the components for the F5 are going to be higher priced than the C300 equivalent. Batteries will be a lot more expensive. SxSPro+ is going to be a lot more expensive than CompactFlash. Some rigging will be required (what do you do with your right hand?) The C300 is viable out of the box. I'm thinking final cost for an F5 is going to be around $25,000.
The F5 looks like a great camera for television and film production. But it doesn't meet my needs for a more compact run and gun/documentary camera. The C300 fits my needs much better.
Brett Sherman is offline   Reply With Quote
Old November 4th, 2012, 11:13 AM   #45
You only need SxS Pro+ for the higher end codecs - for XDCAM422 normal SxS is fine. And for batteries then although they are introducing a new range, I believe any V-lock will do. And using V-lock batteries can be quite significant if you need to power accessories such as radio mic receivers, battery light etc. I think your question about your right hand is answered if you get the shoulder mount option - I seem to recall photos with a handgrip?
But it's unlikely that any one camera will be optimal for all situations, 100% of the time, and yes, it's quite likely that for some situations the C300 may be preferable.
But the F5 does look as if it has more scope for growth should your requirements change. XDCAM422 for now - as the C300 - but the possibility of XAVC, and/or the 4k recorder in the future.
I think it's silly to call anything "future-proofed", but these cameras may go a fair way towards it. I think what Jim is more likely trying to say is it will compete more with the C300 for price, but the C500 for features.
I'm still waiting for real, on the street pricing. Far too much guessing going on!
David Heath is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
